Thread: Oil warning on dash
    N Wales
    Default Oil warning on dash
    Today an 'oil can' sign has come on the dash. Went off when stopped at services but came back on hour or two back on motorway. Its a 1.8 54 plate estate.
    Oil level is spot on and its run around 3000 miles on fresh oil and filter.
    Is it likely to be sensor or genuine pump/engine problem?
    Cheers in advance guys.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    what one and colour was it? in the screen or a actual warning light?
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Oil can symbol (Yellow pixel display)means that you are due a service...
    Oil warning light in red is a faulty pressure switch
    N Wales
    oil can yellow pixel, cheers for that is there a reset?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    press trip reset button and at the same time press brake pedal keep them both pressed and turn on ignition.keep brake and trip pressed for 10 to 12 seconds job done ,some don't need brake pedal pressed but need ign turned on /off twice whilst holding trip button in.
    Regular Member Zampus's Avatar
    Cantabria (Spain)
    Some Vx oil sensors are very sensitive to oil level, they show alert warning even when oil level is above 1/3 over the minimum. Add some oil (0.2-0.3l), warning light should be off.
    have you checked in the manual to see exactly what it means?
  1. warning light on dash
    By tj56 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2011, 14:50
  2. dash warning light
    By graememk in forum Engine & Drivetrain
    Last Post: 1st November 2010, 02:26
  3. dash warning light
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 17:49
  4. Warning On Dash
    By Diesel279 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2009, 20:16
  5. warning ligts on, on dash
    By Gr4eme in forum Engine & Drivetrain
    Last Post: 9th October 2008, 19:35
