Thread: CDTI gearbox bolt patern
    ireland
    Default CDTI gearbox bolt patern
    I need to know does the 1.9CDTI use the same bolt patern as GM's big block petrol engines (x20xev,z22se,z20let,z20leh.......)or does it use an adaptor for the bellhousing(like saab did when they used a GM gearbox on their 2.3turbos)? i think the 1.9 cdti uses two different gearboxes the m32 and m40(is this true, If so which models used which g/b?), is the m32 the same gearbox as the z20leh's only with diferent ratios.
    The reason i am asking is because i want to put this engine into a RWD car and i am hoping GM make a strong enough gearbox in RWD format, if the bolt patern is not GM's patern i will have to look for a rwd fiat that uses this engine. Its very complicated and any help would be greatly appreicated.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the bell houseing patern isnt a gm fit i dont think but you would have to check to be 100% as for do gm make a rwd box strong enough the omega / carlton boxses were bomb proof in fact there still fitted in the corvette and monaro (6speed) so they do have strength .....weather you could bolt it top a z19 is yet to be seen ....
    just a bit of info .....rover fitted the 1.9 into some late 75 mules and the 75 has a f23 gearbox fitted so the parturn maybe the same (rover killed the 1.9 75 due to the reliability / cost problems how ironic lol)
    ireland
    thanks for that mate, can anyone verify the bolt patern, cheers
    EVERYWHERE
    Fiat's Sedici is 4 wheel drive and is fitted with the 1.9 diesel engine. So plenty of options there as long as you keep a transverse engine configuration.
  1. would you recommed patern parts or genuine
    By veclee in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2012, 23:16
  2. 2.2 TDi gearbox drain bolt ?
    By tosh23 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 22:45
  3. CDTI Banjo Bolt
    By JamesG in forum Engine & Drivetrain
    Last Post: 1st February 2008, 14:17
Vectra c gearbox bolt size
