Thread: any ideas what to look for??
    Full Member chunkster's Avatar
    North east HQ
    Default any ideas what to look for??
    my brother is moving up the ranks from a calibra to a vec b 2.5 v6 - only thing is we dont know what to look for fault wise, any suggestions
    its a p reg vectra saloon, 107000 miles, timing kit fitted at 97000 miles,
    it is on ebay http://cgi.ebay.co.uk/1997-VAUXHALL-...QQcmdZViewItem your help is appreciated
    Wayne -
    Here, there and every where!
    Make sure he does NOT go anywhere that does not have a petrol station within easy reach. Even driven "carefully" they are a bit on the thirsty side
    Nicking Ya Dinner.
    DIS unit distributor/coil pack
    Uneven idle
    Rear bushes, push it into a roundabout, if it twitches, you know the bushes are on the way.
    Water dripping from exhaust, potential head trouble, esp this time of yr.
    Steering UJ, inside the car, you will feel uneven movement at the wheel if it has play.
    Airbag and ABS lights, make sure they illuminate, otherwise its bulb failure of fault, anything more than a bulb is mega money.
    any hint of exhaust noise in the enginebay.. the blow may range from a simple gasket (pence) to the common cracked manifold (£££)
    un-even rear tyre wear..
    clunky anti-roll bar links..
    North east HQ
    thanks for the info fellas
    Wayne -
    Dis pack failed on mine too. The rear arches rust quite badly, the timing belt needs to have been done no later than 80K intervals although they later changed it to 60K a year later. The gearbox can be a bit vague and if the airbag light is on all the time its because the seat belt tensioners have a dodgy connectors under the drivers seat. Common fault. Also the steering may ‘clunk’. Again a common fault casued by play in the knuckle joint at the base of the steering column. Not too bad on juice, mine was more economical on long runs than the 1.4 corsa sri I had before, due to the relaxed nature of the V6 cruiser. Unless its had its springs changed for later ‘lotus’ developed ones, 98 onwards, it will handle like a boat as they sit quite high for a sports model. Check for oil/water m ix too as it may not be the head gaskets, but could be the oil cooler which sits between the two heads and can leak sending oil into the waterways. That’s expensive to fix.
    Regular Member Ian's Avatar
    York
    can only second the oil cooler. That blew on my v6 cav - result was rebuild engine cos the added pressure will blow the head gasket(s) and score the bores. ££££ (2k infact)
  1. Anyone got any ideas
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2011, 16:42
  2. Ideas Please
    By Tomb in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 16:21
  3. Any Ideas ???????
    By johnnyd2003 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 21:13
  4. Any ideas as to what this is
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2008, 21:21
  5. Any Ideas?
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 16:49
