Results 1 to 10 of 15
Thread: Key Fob Batteries
    Jul 2009
    london
    Default Key Fob Batteries
    Hi Folks
    I've had mine since Sep-2007 - bought it as a pre-reg from the dealers. So it's over 2 years and 3 months now. It's a Vectra 1.8 Exclusiv.
    Could anyone help me out with a bit of advice on how frequently I should replace the Key-Remote-Fob batteries ? - I used to replace them in my old Vectra (2000 reg) every 2 years., so was wondering if that would be the case with the 2007-model as well.
    Also could anyone let me know how to open the key-remote-fob, and also what battery type (model no. etc) that I need to get (best place to get them ? ) please.
    The thought of getting stuck somewhere isolated with a 1-yr old in the back seat is haunting me , needless to say anything about the missus for sure she will burn me down alive if anything like that happens !
    thx
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Hi..if you look at the back of your keyfob there is a black rectangle, which is part of the main body and is part of the design. above the actual key itself is a small recess which is adjacent to the rectangle.
    Insert a small flat bladed screwdriver into the recess and twist. Your key should then 'break' into two pieces with the key blade seperate to the main body.
    The main body then simply splits to reveal the battery. 3V CR2032,cost approx £2.00 and available anywhere like Maplins etc.
    HTH.
    Jul 2009
    london
    Thanks for the advice mate - how often did you have to replace yours ?
    Regular Member Terry Tibbs's Avatar
    Aug 2007
    i tend to change mine every 2 yrs, better safe than sorry. isnt this included as a service item? i'm sure i've seen something in the service booklet for changing batteries.
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Changed one 2 yrs ago and the 'spare' last week. Had the car approx 2 years. Spare then wouldnt work,on remote functioning until i started the car with it...
    Sep 2009
    Belfast
    Just had a 2nd year service and they changed the batteries in mine keyfob (charged me £3 as well) .
    Jul 2009
    london
    just about to order the batteries from 7dayshop - could anyone confirm how many batteries are needed for one remote - cheers
    Regular Member videodoctor's Avatar
    Blackpool
    Just one for each remote.
    Melbourne, Australia
    I only change mine when they go flat!
    You can still unlock the doors manually and start the car without the key battery if necessary - try it if you need to convince yourself.
    Quote Originally Posted by stevedee3 View Post
    I get a message on the radio display informing me when they're low.
    Yes, you can still open the doors with the key, but the alarm sounds until you start the engine.
    For the sake of 50p to £3 (depending on where you buy a battery from) it's not worth the fuss of not bothering to change it when you know it's on it's way out.
    Besides that though, a franchised Vx garage should change the fob battery every 2nd service.
  1. Key fob batteries??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2012, 08:26
  2. Batteries
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2010, 17:42
  3. key fob batteries?
    By tonyblade in forum Vectra C / Signum Troubleshooting
    Last Post: 16th February 2009, 21:46
  4. Key batteries
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 21:01
  5. Car batteries
    By Ste in forum General Chat
    Last Post: 27th January 2008, 20:33
replacement key fob for vauxhall vectra derby
vectra c keyfob will it start car if it was flat
Change battery in key fob vectra
