Results 1 to 10 of 17
Thread: Sump Plug Nut
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Sump Plug Nut
    Chaps,
    My oil change is WELL overdue (been putting it off due to old weather ) so gonna do it this Saturday whether it's snowing, raining or whatever. But from here I've seen there maybe at least two types of sump nut.
    Can anyone tell me the different sockets sizes I may need so i'm not caught short??
    Cheers all
    Si
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    off hand i can't remember but you do not need to change your sump nut with your oil change, sometimes its worth changing the copper washer but i only changed that once in all the oil chnages i did on my veccy B.. for my signum I changed the washer as i did know the history of the car prior to me buying it and giving it a full oil/filter change.., I keep spare washers just in case but doubt i will change it on the next oil change next month.
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Caveman_nige View Post
    Yeah I understand that, just asking what socket size as I believe some maybe torx E##, as I don't own many torx/star sockets I'll have to buy one first, just not had a chance to get underneath yet to actually look myself.
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    for how much they cost worth getting one just in case .... if its your first oil change you doing yourself get one you never know if its been over tightened before .. if its the torx one then can have stripped splines... at least you will have one if you have to attack the old one
    Jun 2009
    South Coast
    the torx ones are a pain in the butt, if you replace it just buy a normal sump plug that you can undo with a normal socket/spanner
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Mines a t45 i think, pain in the arse unless you can get right under neath, as so easy to round off.........voice of experiance.........
    Oct 2009
    Swindon
    I think E45 is correct, don't forget to get the rubber O ring to seal the sump plug with.
    Wales
    Mine (1.9cdti) is a nut type - 13mm, but a 1/2" socket is actually a better (i.e. tighter) fit on it, so I use that. They are only tightened to 25Nm - 30Nm or so.
    Motherwell Scotland
    You dont mention the year of your car but I have changed the oil on my 56 reg 1.9cdti. The plug is a 13mm torx socket which means it has six sides(hex) not 12 like a normal socket. Dont try it without the right socket as it will slip and burr the nut. Mines was very tight and took a bit of moving. Hope this helps.
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by st2malo View Post
    Cool thanks everyone!
    Mines a 2002 2.2DTI so I'd guess a hex-nut rather than torx number, as I say if it is the torx socket then I now know it's an E45 (which I thought was moisturising cream...... )
    Cheers all!
  1. Sump plug
    By shb1988 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:37
  2. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  3. Sump plug
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 2nd June 2012, 22:47
  4. Sump plug
    Last Post: 8th May 2012, 20:46
  5. sump plug on my 2.2 sxi
    By smilerwas in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 22:53
vectra c using hex sump plug www.vectra-c.com
06 vectra 1800 sump bung
