Thread: heater motor has stopped.
    Witham
    Default heater motor has stopped.
    i have a vectra elite 54 reg 1.9cdti. over the last few days the heater motor has been erratic, but has now stopped altogether. i have had the fuses checked, they are fine. there is also clicking sound coming from the glove box area. any ideas?
    Sep 2009
    warwickshire
    hi. heater motors are common problem.normally due to water getting in to them through the pollen filter.because the drain is blocked up.so you need to look at that first. their are plenty of threads on here to help.
    Sep 2009
    Swindon
    Have you tried it on setting number 4? if it works then it will be the therma fuse, 69p from maplins if not maybe a relay.
    Frenchman
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There are 2 relays above the glovebox. One switches on when switching to blower position 1 and stays on up to position 3, the other relay activates at switch position 4 only.
    This is for standard A/C with manual blower 0 - 4 speeds.
    Witham
    We have taken out the regulator (we don't have a resistor as our car has climate control) and it smells of burning. Checked inside and looks burnt out. The heater/blower was not working at all not even 1-4, so could it be the motor, or just the regulator?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would try simply attaching 12+ across the blower motor and seeing if it works. That will tell you if the blower is defective, or the regulator.
    Witham
    Thanks for the replies - we fixed it. It cost £175.00 from vauxhallworldparts.com.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What was the problem?
  1. Washer motor stopped?
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2012, 01:50
  2. Heater Blower Motor suddenly stopped
    By Snizzers in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2012, 22:58
  3. Help, my Heater Has stopped working
    By nessie455 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st January 2010, 18:54
  4. heater stopped working
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 07:56
  5. Heater blower has stopped working
    By Dave1971 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2008, 12:55
