Thread: Boost valve torx bolt??
    Jun 2009
    Chelmsford
    Default Boost valve torx bolt??
    Took boost valve off yesterday to clean and now the torx bolt will not tighten up again, although it tightens up ok without the boost valve in place?? Anyone have any ideas, seems like its not long enough to catch thread in hole???
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Sounds like you haven't seated the boost valve properly
    Jun 2009
    Chelmsford
    its in as far as it can go, bolt is just not getting a grip??
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    cross threaded bolt - you need a new one (bolt)..
    check the bolt thread and see if you can see where the bolt has been cross threaded.. If it tightens when the boost valve is not in place this would confirm the cross threaded bolt as the bolt thread will be gripped further up the bolt due to the boost valve not being there.
    A
    Jun 2009
    Chelmsford
    i'll pop to Halfords and get a new one tomorrow, i guess its a standard size??
    Mar 2007
    Southport
    As AntSSS says, check the threads at the end of the bolt, you should be able to see if they're damaged or worn
  1. Fitting interior in vectra c rounded torx bolt
    By IRvectra786 in forum Bodywork & Interior
    Last Post: 18th December 2012, 21:53
  2. Steering Wheel bolt torx size
    By Vectra Forever in forum Bodywork & Interior
    Last Post: 18th July 2011, 22:06
  3. Torx Bolt Size - Rear Suspension Dampers
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2010, 16:51
  4. Boost Sensor Hex bolt Q
    By Sch3cter in forum Engine & Drivetrain
    Last Post: 1st September 2010, 09:17
  5. TORX bolt size ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2008, 15:19
