Thread: Sub and amp now fitted
    Regular Member S888 SRB's Avatar
    May 2006
    Hemel Hempstead, Herts
    Default Sub and amp now fitted
    Finally got round to fitting my soundstream amp and bazooka bass tube.
    Wanted to keep the standard CDC 30 headunit so added a line to RCA convertor. Stripped the interior and ran the power lead through the grommet in the bulkhead, down the nearside through the wiring conduit and into the boot.
    Did the same on the offside with the RCA leads and remote lead (the remote lead had to be wired from the fag lighter as theres no electrical pulse from any wiring connected to the back of the stereo (is this whats known as CANBUS?)
    Placed the amp in the boot and secured all the wiring, vecro'd the bass tube to the side of the boot trim and fired it up, all good.
    Except that if its turned up, it sounds cool but when you turn it down it seems to have a low volume bass enhancement that causes the sub to distort at lower volume levels.
    Also when you have the speed dependant volume control (SDVC) turned on, it starts to sound tinner the faster you are going so i turned that off.
    Can i turn this bass enhancement thing off?
    Dec 2005
    In the sponge-monkey tent
    Just a thought but have you got the 'loudness' setting on or off? This might be causing the low volume distortion???
    SOMERSET
    Hi Mate, What i have found is when you are running sub's and amps off a standard head unit, the information from the unit tends to be ****. You mention that you have a RCA adapter................ stop that's ya problem. When your system is on low volume's the information it send's to the amp is good, when you crank it up your head unit goes week at the knee's. You need a IN-line driver that will boost the signal from your head-unit to your amps thus giving you proper sound and CRONTROLLED base.
    Like Spike has mentioned the standard head unit should be set at 0 or setting's and loudness turned off. Your amp's should dictate what your sub sound's like not your head-unit.
    May 2006
    Cheers for the thoughts guys.
    The convertor is an Autoleads unit fitted by Impulse, the people my company use for ICE work. It has a pair of gain controls on it which i didn't fiddle with because my mate whos the fitter told me they are set to an ideal level.
    It does sound good(ish) at both upper and lower levels but you either have to have it set quite low or high on the volume. The bit in the middle is so so...
    Is there a loudness setting on this unit? tried scrolling through the controls but can't see anything. Maybe i should RTFM
    Still i'm pleased to have my bass back!
  1. just fitted the k&n 57i .
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 22:49
  2. Hid fitted
    Last Post: 29th December 2010, 19:16
  3. anyone got or fitted??
    By vectra_c_wannabe in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2010, 09:50
  4. Just Fitted.......
    By KeefyB in forum Petrol Engine related
    Last Post: 22nd January 2010, 21:38
  5. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
