Thread: Rear Screen Demist Issue-Leaves top 3 lines on Fiesta Mk4.5
    Birmingham
    Default Rear Screen Demist Issue-Leaves top 3 lines on Fiesta Mk4.5
    Hi guys,
    On my facelift Mk 4 Fiesta when the rear windscreen is demisted, it ALWAYS leaves the top 3 lines, and then clears them once the rest of the screen has demisted (after about 7-10 mins).
    I have noticed this on another similar Fiesta too that was for sale somewhere as well.
    Is this a common problem, if SO, whats the fix? Is there a Fix? A quick DIY ?
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Worcs/Staffs/Westmids (ish)
    I doubt this can be fixed, the heater matrix (the thin copper strands) have burned out or been damaged/scratched/broken. I don't know if they can be soldered, never tried.
    Looks like a new rear window to me :\
    Regular Member SRimonkey's Avatar
    wednesfield
    if there`s a break in it there`s like paint stuff you can buy to repair the break
    Jun 2009
    doncaster
    is that all? try my 1980 mk1 fiesta then!,that demists in 7-10 days! the power supply on that leads from the bottom of the rear screen towards the top i think it starts running out of current because it takes ages to demist 3 quarters of the way up!,i just leave it to heat up and its fine so maybe its just a fiesta thing?
    Edinburgh
    probably the top 3 have been damaged, can you see a scratch through them? As mentioned above you can by Electro-conductive paint to repair it.
    It will eventually clear as you've noticed because the other onces are slowly warming the glass up (heat rises)
    Birmingham
    Quote Originally Posted by SRimonkey View Post
    Any idea's where from? Is it cheap? Or am I better off getting a new screen, or leave as it?
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    [quote=bat30;1176696]is that all? try my 1980 mk1 fiesta then!,that demists in 7-10 days! [quote]
    Absolutely !!!!
    Bye bye Vec B
    - Hello Siggy!
    wednesfield
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It depends on how the last 3 lines clears. If they clear slowly from bottom to top evenly then they are probably broken. If they clear from each wire up and down, then they are probably just working slower and may just be slightly defective OR they could be designed like that so the most important bit clear first? Are these lines in your normal field of view when using the rear view mirror to see the road behind?
    Birmingham
    Quote Originally Posted by Ste View Post
    Thats the problem, YES> if its designed like that, then thats pants!!
    Bye bye Vec B
    - Hello Siggy!
  1. Rear Screen demister issue
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2013, 08:54
  2. Rear demister lines knackered.
    By elle2801 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2013, 13:12
  3. Rear Screen Washer Issue
    By Kev_G in forum Bodywork & Interior
    Last Post: 21st March 2011, 00:39
  4. dreaded wipers parking up the screen issue !!!!
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2010, 14:32
  5. Fiesta Mk5 Radio Signal Issue
    Last Post: 9th November 2009, 14:06
