Thread: White Smoke 1.9 CDTI 120
    Oct 2009
    _
    Default White Smoke 1.9 CDTI 120
    Another fault with my 06 Vectra.
    I would say 2-3 times a month now the engine decides to smoke. It's white smoke and smell like oil/diesel which rises from the engine bay. It seems to go after it is turned off and restarted. The car runs fine otherwise, no smoke from exhaust and has been recently serviced. As it's only happening now and again, I can't get out and see exactly where it's coming from. Anyone give me advise on what to check or has experienced this too? I was looking at cleaning the EGR are too, where is this located on the 120?
    Cheers.
    Oct 2009
    _
    EDIT: I found the EGR, will be doing that today.
    Oct 2009
    _
    I'm hoping that this was the culprit!
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Did you clean it or replace it?....hope it sorts the job anyway
    Oct 2009
    _
    I'm just cleaning it for now. If you note the space in the washer, I turned this around when re assembling to match the grooves on the flange. Fingers crossed!
    Oct 2009
    _
    Well it smoked after I cleaned the EGR. Looks like it's coming from the turbo area. I thought if the turbo was compromised there would be white smoke from exhaust?
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. White smoke
    By Mark fisher in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2012, 10:42
  3. Replies: 18
    Last Post: 20th November 2012, 21:41
  4. white smoke help
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 29th June 2012, 22:59
  5. white smoke cdti
    By km101 in forum Engine & Drivetrain
    Last Post: 14th November 2007, 22:28
vectra c white smoke
vectra 1.9cdti 120 white smoke
vectra c 1.9 120 white smoke
white smoke from vectra c
vectra 1.9 cdti white smoke and hard to start
why is there white smoke coming from my vectra c when i start it
