Results 1 to 3 of 3
Thread: 3.0cdti starter fault
    Sep 2009
    bedford
    Default 3.0cdti starter fault
    Hi All
    Can anyone help with a intermittant, I think starter fault about two or three time a month it appears to not engage an make the noise as if not engaging the ring gear I have had two garages look at it and it has not done it after starting it a lot of times,could it be a dirty shaft it is automatic so would not have any clutch dust,or could it be something to do with the ignition switch, any comments would be apreciated thank you.
    If it is so intermittent and rare, leave until it becomes more permanent
    A faulty starter motor is quite easy to diagnose as it normally won't engage at all but you can hear the starter motor firing
    If the ignition switch was faulty then the starter motor won't be receiving electricity, however when faulty these usually fail completely and aren't intermittent
    Personally it sounds like some loose wiring
    Has the engine or gearbox been removed from the vehicle at any time?
    Regular Member sharpo's Avatar
    Jun 2009
    York
    Mine did it a couple of times, turned out to be in need of a new battery, sounds odd but true, if you take it to a decent garage they may have the correct meter to test it for you.
  1. P0615-02 Starter relay circuit voltage (fault code any help)
    By eaglepva in forum Engine & Drivetrain
    Last Post: 18th September 2011, 15:17
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. starter solenoid or starter cdti 150 help!!
    By veralum in forum Engine & Drivetrain
    Last Post: 27th April 2010, 19:57
  4. Possible starter motor fault?
    By marley in forum Engine & Drivetrain
    Last Post: 9th April 2010, 17:27
  5. 3.0CDTi, new fault or SCV related?
    By Celes in forum Engine & Drivetrain
    Last Post: 14th December 2009, 00:23
vectra cdti how to diagnose faulty starter motor
