Thread: Radio Help
    Jan 2010
    Bucks
    Default Radio Help
    Hey guys,
    Having received my car back from the garage the stereo as showing the word "safe" so i assume the battery was disconnected for some time.
    I have the radio code so followed the routine as found on this forum.
    I switched the unit off
    turned the ignition on
    turned the radio on
    press and held AS and nothing, no beep, no word "code" nothing
    So any help on how i can get the steroe working would be great as its very quiet in my car at the no.
    Its a 2003 LS Vectra
    Thanks in advance
    May 2008
    Tyneside
    You have to hold the AS button while turning the radio on. HTH
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hold the AS button then turn the ignition on, then you will get _ _ _ _ then put in your code HTH
    Jan 2010
    Bucks
    Worked a treat, Thanks guys.
    Pete
  1. CDC 40 radio
    By dave b in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2012, 23:20
  2. Radio 1
    By vec-cal in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2010, 00:17
  3. my radio
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 21:29
  4. CD 30 Radio
    By Stevel in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 13th July 2008, 17:15
