Thread: how low would you go.
    Regular Member sla002's Avatar
    hayes, middlesex
    Default how low would you go.
    hi all,
    1.9 cdti 150 veccy.
    how low can i go without any trouble and staying on standard shocks.
    just want slightly better handling and a lower look.
    Regular Member dawasdave's Avatar
    Norfolk
    I personally wouldn't go too much more than 30mm on standard shocks... Be worth trying to get some vxr ones...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Is it an SRi..?
    If so, then you can go as low as -45mm*, if it isn't then 30mm* (as above) is your limit.
    * the above amounts are -15mm if it is an SRi.
    hayes, middlesex
    how much lower are sri springs than standard. 25-30mm?
    Regular Member yadziyad's Avatar
    London
    its 15mm lower than standard ones
    Jun 2009
    doncaster
    i had a 97 reg diesel corsa a few years back on 15's which was lowered at 40mm!,the rims were in the arches!,it looked the k9ns mate!,handled brilliant too!
