Thread: SMD's or LED's for lighting...
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default SMD's or LED's for lighting...
    Which would be better or brighter for footwells and theboot etc, maybe even exterior...
    Seen some SMD strips that look pretty neat and flat (sticky backed etc) but not sure how bright they would be...
    Cheers...
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    led strips are really bright mate thats what i have look the dogs
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    One led provides less light than a bulb, but most foot-well lighting mods have several LED's in, which provide loads of lighting...especialy if you go for the white LED's.
    Coloured LED's are nowhere near as bright as the white ones.
    Note also...normal bulbs have a slightly yellowy tint, purely because of the materials used to make them (tungsten fillament).
    SMD's are just a differently constructed / format of LED.
    SMD is merely a surface mounted Diode
    LED is a light emitting Diode...so best thing to check is the MCD or Lux rating...the higher the value, the brighter the light.
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    also a led is not a light if we are gettin technical its a light emiting diaodealso a led does no produce anyheat what so ever
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    also you can go for a 2 colour led and power them with a special switch with reverses its polarity feed which would then change them to their 2nd colour
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jul 2009
    The Rift, Cardiff
    Quote Originally Posted by plasma View Post
    giving me ideas, blue or maybe red footwell light that turns white when the doors are opened, ie interior light comes on. that would be
    18 Post(s)
    Mileage : 110k
    Thanks for the Schooling lads, but i only needed to know if SMD's would be bright enough all my other cars have been like christmas tree's, but only ever used SMD's for smaller spaces like exterior handles etc... not boots and footwells
    Will have to look into this, anyone know what to search for on fleabay?
    Definalty going to be white Robsey by the way, probably go with led strips then...
    18 Post(s)
    Mileage : 110k
    Has anyone else fitted simillar to these for footwells etc?
    http://cgi.ebay.co.uk/30cm-LED-Water...ht_4901wt_1165
    Just trying to figure out how close to something they'd need to be to for it to glow up? if i make sense... footwells are what, 40cm high roughly?
    Or there's this type, i'd gather brighter (cant see by loads) but wont hide as neatly...
    http://cgi.ebay.co.uk/24cm-White-LED...#ht_2058wt_939
  1. SMD's for dash etc
    By chrissy white85 in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2012, 17:26
  2. Powerind smd's/led's while modding
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 15th July 2010, 13:46
  3. What size SMD's?????
    By connery-sri in forum Electrical & ICE (including SatNav)
    Last Post: 7th July 2010, 20:53
  4. powering SMD's
    By B4rrett in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2009, 09:05
