Thread: HELP....the 2.2 direct saga goes on!
    Regular Member edwardabud86's Avatar
    Aug 2009
    luton
    Default HELP....the 2.2 direct saga goes on!
    Right, where do i start! I actually cannot put into words how much i hate this engine!
    i have had the car 5 months! first i replaced the battery, then the ecu, then it was the inlet manifold! then it was the fuel regulator and fuel pump!
    After spending copius amounts of money on it and finally getting working again, i took it for an mot today and it failed! miserably!
    firstly, offside rear shock has a fluid leak. this one i can cope with, annoying but expected, as its another common fault for the signums!
    Secondly, parking brake lever has no reserve travel. im not sure what this means, but when the car went into vauxhall they fixed the handbrake as apparently theres a manufactures fault with them. so they did it for free as they had called them all back.
    Thirdly, Its failed on exhust emissions! Co reading was 0.571% ! Its supposed to be 0.200%! They said it could be the mani cat! thats another £600! But it could also be the EGR Valve or something!
    What the hell is the manicat all about? what a ripp off!! why cant they just make it a single cat unit?? theiving gits!
    does anyone have any idea how i can get it through this mot cheaply so i can get rid of the poxy thing and buy the turbo veccy im longing for??
    Cheers ed
    P.s sorry bout the rant! Just a litte upset
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Track car ? Break for parts ?
    Aug 2009
    luton
    Quote Originally Posted by Handyandy-UK View Post
    Tempting. but i dont wana give up on it after so much work!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Manicat, the manifold and cat are one part on the 2.2, you could try fitting one from a breakers, its not a common fault for them to fail. The EGR can be cleaned by yourself, just be prepared when you take it off as its water cooled.
    Aug 2009
    luton
    Where abouts is the egr?
    Vehicle : SRi
    Mileage : 137000
    Its bolted to the side of the block (next to the battery box) This is the none direct but its in the same place.
    Its the barrel shaped thing on mine.
    Regular Member dawasdave's Avatar
    Norfolk
    Gutted for ya mate.. Sounds like your having a tough time of it...
  1. Another tyre saga
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 13:03
  2. My MOT Saga.....
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2009, 20:51
  3. What a saga!
    By JagRigger in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2009, 20:23
  4. Continuing car saga
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2008, 14:26
  5. The Saga Nearly at an end ... Hopfully
    By Robatel in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2006, 03:12
