Results 1 to 10 of 20
Thread: HELP!! Fed up vec owner - now having power problems
    Regular Member Vecmaniac's Avatar
    Oct 2007
    Morpeth, Northumberland
    Default HELP!! Fed up vec owner - now having power problems
    How fed up am I.... Following on from this thread - http://www.vectra-c.com/forum/showthread.php?t=99666 I now have a power loss problem under 2500 rpm! I've had this before leading twice to a new egr valve and once to a new inlet manifold!!
    I had the egr valve out tonight and gave it a clean, although it wasn't that bad with the solenoid free and just the slightest resistance form the valve itself which was sorted with a squirt of wd40.
    Refitted but no improvement.
    Checked the actuator rod on the inlet manifold but as the manifold was renewed mid last year as I suspected it was fine and moved without problems when the engine revved.
    No management lights just a dangerous lack of power... I am fed up to the back teeth now and this will be the last VX I own after almost 20 years of them!!!
    I've never had a car like this...EVER!!
    Bit of a lame question... would an overdue oil change cause a loss of power under 2500rpm and lower than normal fuel consumption?
    One other question... Can an EGR valve fail even though it is free and no management light is displayed?
    Regular Member degsy1234's Avatar
    Jan 2010
    Here
    a mate of mine has this problem so he spoke to a mechanic he goes to who said he will block the egr valve off! He said its the worst thing vx ever put on a car and you can just block it off all it does is burn left over exhaust fumes.... i'll see how he gets on
    Oct 2007
    Cheers for that but I think (could be wrong here) that there are gas flow detection issues that can't be overcome if the egr is blanked off on a cdti 150?
    What I really need to know is of an egr can be faulty even with no management lights and all components on it are moving free on inspection.
    Jan 2010
    Here
    ill let ya know what happens his is a saab 1.9 150 diesel same engine i believe
    Bristol
    Vehicle : CDTI 150
    The CDTI (FIAT JTD) engine needs to detect the the mass of gasses from the EGR or you will get a fault lamp. This cannot be coded out with Tech 2 etc, however there are some maps that have had the software rewritten to get around this and allow thw EGR to be blanked.
    Oct 2007
    Thought as much, that makes sense.... Getting back to the question.... Can an egr be faulty when not seized and no fault light?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Stupid question but does the rod move when the accelerator is pressed ie revved up passed 2,500rpm? If not then the swirl valve drive module has given up.
    Ignore this
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Oct 2007
    Yeah, I checked that right after the egr and it's fine (the inlet manifold was replaced mid last year)
    Bristol
    Vehicle : CDTI 150
    When you mean not seized whilst the bit that sticks out of the solenoid may be free to move you need to remove the solenoid by drilling and knocking the plunger out then cleaniong and lubricating.
    An EGR can be sluggish this can cause the symptoms you're experiencing, occasionally no matter how well cleaned only a replacement will cure.
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by lesj View Post
    probably better off with drilling the old one, knocking out the solenoid and lubricating it as the how2 shows as this works and probably better in the long run.
    Gazza4
  1. power problems
    By DavieVectd120 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 17:21
  2. No power after major problems
    By adam3682 in forum Troubleshooting
    Last Post: 4th August 2009, 15:16
  3. Power steering problems !!
    By mark_647 in forum Engine & Drivetrain
    Last Post: 23rd May 2009, 19:10
  4. Power problems
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 10:28
  5. Power problems on my 1.9CDti (120)
    By RedLine in forum Engine & Drivetrain
    Last Post: 26th July 2008, 22:21
