Likes Likes:  3
View Poll Results: CDTI only Which Eibach spring kit did you fit
Voters
90. You may not vote on this poll
  • Eibach spring kit 10-65-007-01-22
    17 18.89%
  • Eibach spring kit 10-65-007-02-22
    20 22.22%
  • Other spring kit
    7 7.78%
  • Still Standard springs
    22 24.44%
  • just browsing ;-)
    24 26.67%
Page 7 of 7 FirstFirst ... 567
Results 61 to 66 of 66
Thread: CDTI only Which Eibach spring kit did you fit
  1. #61
    Jul 2014
    United Kingdom
    Vehicle : vectra
    Trim : sri
    Engine : cdti 150
    OK so I'm about to buy some eibachs for my 2007 1.9cdti Sri
    hatch
    To summarise if you want the front to sit slightly higher people are going for the Pro-Kit (E10-65-007-02-22)
    If you want it lower on the front you go for Pro-Kit (E10-65-007-01-22), even though the axle weight of the car is1065kg and the eibach (E10-65-007-01-22) springs are rated at max 1060kg is this correct?
  2. #62
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I went for the correct ones, i think @RichM tried the lighter duty front ones. Also depends on what wheels you have.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  3. #63
    Regular Member TomC281's Avatar
    Mar 2015
    Wokingham
    23 Post(s)
    Vehicle : Vectra C 1.9 CDTI
    Trim : XP2
    Mileage : 167k
    I went for the lighter rated springs on my old cdti and it sat great. Same arch gap on front and rear
    Sent from my SM-G935F using Tapatalk
  4. Likes Dog_Book liked this post
  5. #64
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Trim : Elite with sports pack
    Engine : CDTi 150
    Mileage : 103000
    Small update on the eibach springs still going strong after 8 years on the Vectra
    No problem what so ever,
  6. Likes Dog_Book liked this post
  7. #65
    Regular Member rmsNoel's Avatar
    May 2014
    in my garage
    Vehicle : vectra Cdti
    Trim : design+
    Engine : cdti 120
    Mileage : 51,321
    Has anyone measured the ride height, wheel centre to arch on the different springs?
  8. #66
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    9 years on from my original post..........
    https://www.vectra-c.com/forum/showt...-Ebay-Bargain!
    Broke a rear spring so needed to find replacement, can get rear set for £100 but decided to get set for £140. The upto 1060kg kit always looks good fitted but over a year or 2 a felt that they were a little low and the amount of time a scraped the vxr bumper was too much.....drop was atleast -25mm if not more instead of -15mm. So i've picked up the upto 1135 kg kit and fitted rears to get thru mot. Going to fit fronts with new shocks all round as had her 10 years and 100k. Hopefully the 1135 kg kit will settle OK and not be nose up.....it might take a couple years but hopefully the vxr bumper will survive too.
  9. Likes Dog_Book liked this post
  1. CDTI 150 Estate Eibach Spring Part Numbers
    By Betty in forum Suspension, Wheels & Brakes
    Last Post: 6th November 2012, 13:13
  2. eibach spring help
    By Kev_1664 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 23:29
  3. eibach spring comfort?
    By richg1979 in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2009, 10:35
  4. Eibach Spring Kit - Help
    By K7SH M in forum Suspension, Wheels & Brakes
    Last Post: 29th October 2008, 20:44
  5. Eibach Pro Spring Kit
    By Damian in forum Handling & Braking
    Last Post: 30th October 2006, 19:01
e10-65-007-02-22 vectra forum
