Likes Likes:  1
View Poll Results: CDTI only Which Eibach spring kit did you fit
Voters
87. You may not vote on this poll
  • Eibach spring kit 10-65-007-01-22
    17 19.54%
  • Eibach spring kit 10-65-007-02-22
    18 20.69%
  • Other spring kit
    6 6.90%
  • Still Standard springs
    22 25.29%
  • just browsing ;-)
    24 27.59%
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: CDTI only Which Eibach spring kit did you fit
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Arrow CDTI only Which Eibach spring kit did you fit
    Hi all well after my third VX Spring break i need some help
    And what are your thoughts on them
    the roads around me are full of pot holes so i don't want to go too low
    I Know after reading on here that some think the Eibach kit
    Part Number:10-65-007-02-22 sits too high at the front
    My Axle Weight is
    1065 front
    985 rear
    2006 Vectra Elite 1.9 CDTI
    manual gearbox
    fitted with 18" wheels & sports suspension from the factory
    Cheers for helping me pick a set
    i did email Eibach
    but it just got me more confused
    Eibach reply below
    Thank you for your email regarding springs for your Vectra C
    The difference is that there is a difference in front axle load. The E10-65-007-01-22 is for 1068kg front axle load and the E10-65-007-02-22 is for 1135kg front axle load
    You should be able to find the axle weight of your car on the vin plate
    I've looked all over the web & the kit E10-65-007-01-22 usually shows up as upto 1060kg
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    CDTi 150 BSRi: I've not actually fitted them yet but I have a full set of Bilstein B6's & the 'E10-65-007-02-22' all boxed up & waiting to be fitted.
    I also emailed Eibach prior to purchase & got the twin of your email in reply
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    tbh i rang lmf and told them the weights and they sent me a set and tbh im happy not to high and feels really good now. looking forward to the car settling befroe i know the highs
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    lol I'm now also after the spring mod plastic cover (part number 13178463)
    i found both springs sets for £154 on line with free delivery
    just don't know which set to get
    Cheers for the reply
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    i voted for the second set as ive a elite and this is what lmf said i needed,the front does sit a little high but was told it is the way the front arch shaped ,im happy with this setup . khalid
    Mar 2007
    Southport
    Quote Originally Posted by Thunder View Post
    You have the Vectra Elite 1.9 CDTi so need the same part number as above - go on LMF website select spring, car then axle weight as on the plate by the drivers door
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    Thumbs up
    Cheers Ian
    E10-65-007-02-22 This was the kit i was going to get but then i read on here it sits high,
    And then i emailed Eibach & it came back as i needed E10-65-007-01-22
    i'll have to phone them tomorrow & see with they recommend for my front axle load which is 1065kg
    Thank for the replys
    Mar 2007
    Southport
    With sport spings you need the 13178464 sleeves, they're slightly bigger diameter & green
    Mar 2007
    Southport
    Cheers Ian
    I'll stick to slightly high, I give the drive a good sweep as I pull in even with the SRi springs so reckon I'll be leaving a bit of spoiler behind with the Eibachs
    Regular Member Trist78's Avatar
    Jan 2010
    worcestershire
    E10-65-007-02-22
    Is the one I had ordered and just fitted over the weekend !
    Was not expecting the bigger drop that I had !!
    I have the SRI cdti 150 so I was infromed it will go down by about 15 mil but I would say a lot more maybe 25 mil or more.
    I am also running 18s as well, hopefully I can get it cleaned this weekend and get picture up.
  1. CDTI 150 Estate Eibach Spring Part Numbers
    By Betty in forum Suspension, Wheels & Brakes
    Last Post: 6th November 2012, 13:13
  2. eibach spring help
    By Kev_1664 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 23:29
  3. eibach spring comfort?
    By richg1979 in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2009, 10:35
  4. Eibach Spring Kit - Help
    By K7SH M in forum Suspension, Wheels & Brakes
    Last Post: 29th October 2008, 20:44
  5. Eibach Pro Spring Kit
    By Damian in forum Handling & Braking
    Last Post: 30th October 2006, 19:01
e10-65-007-02-22 vectra forum
