Results 1 to 10 of 23
Thread: brake squeak squeak not a mouse!
    Full Member paul.sessions's Avatar
    leighton buzzard
    Default brake squeak squeak not a mouse!
    after fitting my new brakes yeaterday it has developed a squeak squeak squeak. not continuous. from passenger side, it happens after braking, let foot off brake. pull away slowly or continue moving and hear this noise as i get faster it goes away. strange could it be a warped disc, i haven't been braking hard.
    just annoying sounds like a squeaky door opening.
    any help or advice would be appreciated thanks..
    Paul
    Cambridgeshire
    Could be the type of pads that you have mate. What ones did you fit redstuff?
    Some pads have a 'habit' of squeaking and squealing.
    leighton buzzard
    ebc ultimax. just standard replacment pads, its squeaking when my foot is off the brake.
    leighton buzzard
    anybody any ideas?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The back plate isn't touching the disc slightly is it?
    leighton buzzard
    i will check, have to check tomorrow are you about the thin plate does it go all the way around? it only happened today once the brakes were warm!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Thats the one mate, 80% sure thats what it is if it only does it when hot. The disc expands and touches the plate
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    did you put a smear of copper slip on the backs of the pads? i know they usually have anti-squeal shims attached to the backs of the pads, my VX rear pads did have, but a light smear on the back as well helps.
    leighton buzzard
    yes put copperslip on
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    could be a small stone caught between the back plate & the disc/pad, unlikely its the actual back plate rubbing on the disc, unless you bent it when putting the new pads on, but the plate is reasonably thick so you'd had to have used reasonable force to bend it.
  1. squeak squeak squeak squeak drive belt
    By martygibson1888 in forum Engine & Drivetrain
    Last Post: 8th February 2013, 17:20
  2. Brake Squeak
    By dennis_signum in forum Handling & Braking
    Last Post: 27th April 2009, 21:29
  3. squeak
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 07:26
  4. Squeak !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2009, 11:48
  5. Squeak
    By joules2.0t in forum Suspension, Wheels & Brakes
    Last Post: 18th October 2007, 20:30
