Results 1 to 10 of 22
Thread: Battery discharging overnight
    Jan 2008
    South Lancashire
    Default Battery discharging overnight
    Has anyone solved this problem?
    I have read lots of threads from people with the same problem and lots of advice on how to find a current drain, but no-one seems to come back and say if or how they fixed the problem.
    For anyone who has not read these threads we are having trouble with the battery discharging overnight. We have had a new alternator and a new battery but problem remains.
    The local auto-electician says there is no drain but still the battery is flat every morning.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    try feeling the end of the alternator pulley to see if its getting hot.
    Feb 2007
    North west
    had it once on wifes car, boot light was stuck on.
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    If it is your boot light - look through back seats and see if bulb is permanently on... If so disconnect and reconnect the block the opposite way...
    Mines discharged a few times but its only when its been left unlocked etc, or i've left boot open and so on... when locked and parked up never had issues.
    Derby
    Buy/Borrow a multimeter.
    plug the cable into 10A unfused, and the common sockets. Turn meter to "10A"
    Pop bonnet, and close all doors, wait for all lights to turn off
    remove earth cable from battery
    attatch red lead from meter to battery.
    attatch black lead to removed cable
    Wait about 60 secs for ECU and dash to turn off
    Should read no more than about 0.05
    Anymore and you have a drain. Id assume an overnight drain to be sucking about a 5Amp current (5.0 apx on the meter)
    TO CHECK ALTERNATOR (COMMON DRAIN FAULT)
    With earth lead still removed, remove the cable from the positive terminal of the battery held in by a 13mm hex headed M8 bolt (this is the starter/alternator feed) Ensure its not touching body.
    Repeat test with meter. If reading drops to 0.0, then either alternator or starter is ******ed. Remove the 25a fuse labelled "F2" from the fusebox to the right of the battery. Re attatch M8 bolt and cable to positive terminal.
    Repeat test, if reading 0.0 apx, then starter motor broke, if reading 5.0 apx again, then looks like diode or regulator pack on alternator broke.
    Im having the same issue, and i need a refurb alternator
    Last edited by tshort2007; 15th February 2010 at 22:43. Reason: added TO CHECK ALTERNATOR (COMMON DRAIN FAULT)
    Jan 2008
    South Lancashire
    Quote Originally Posted by tshort2007 View Post
    Thanks for reply it is very detailed, however we got so frustrated we have left it with the local auto electician.
    He insists that if it was the new alternator (supplied and fitted by him) that it would show up as a fault on the dash.
    If he finds out problem I will post the solution so that you can check it on yours.
    We were told that it is not possible to refurb these alternators our new one cost £!70 plus fitting, the bill came to £280.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Following on from my past posts then reading this thread, I've had no further issues (yet ) with battery discharging overnight ( or over a couple of days) since fitting a new higher capacity battery 4/5 weeks or so ago..but have not done a 'drain' test since.Perhaps the extra capacity of the battery has enough charge left to appear to have 'solved' my problem, but plan to do "tshort 2007's" test shortly as I still believe something may be 'wrong'... Cheers.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    To do a more accurate drain test, you should hold the bonnet alarm plunger down and lock the car with the key fob, then check the drain current when it has fully powered down.
    You will have to figure out how to lock the car with the battery still connected, wait for full power down and then remove a lead from a battery post and still have the multi meter connected between terminal and lead wire connector (I'd have thought you don't want to interrupt the power supply to the car at all)
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    plug the cable into 10A unfused, ..................................... and i need a refurb alternator
    Wow, thats a great bit of info, i'm having the same problem myself at the moment but I have a sneaking suspicion its the glove box switch fault (took bulb out last 2 nights and multimeter readings have been looking good).
    Jan 2008
    South Lancashire
    Quote Originally Posted by Tony W View Post
    What capacity battery did you fit? We fitted a new 70 amp battery.
    This is the normal size for signum deisel 1.9L 150.
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Cracked windscreen overnight
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2010, 13:06
  3. Battery discharging overnight
    By H&S-Blaz in forum Vectra C / Signum Troubleshooting
    Last Post: 8th March 2010, 18:31
  4. Overnight stay suggestions
    By stusdc in forum General Chat
    Last Post: 26th June 2007, 23:58
  5. Who Painted my car Overnight....
    By spoons in forum General Chat
    Last Post: 3rd February 2007, 16:15
