Thread: Boost valve cleaned, now EML light on
    Jun 2009
    Chelmsford
    Unhappy Boost valve cleaned, now EML light on
    Went out in car this morning and spanner light appeared!! got home and cleaned boost valve as i intended to do today, it was well dirty cleaned up with carb cleaner spray, refitted but now cant tighten up torx bolt, also on starting car again, spanner light shows for a few seconds then dissapears but orange engine light now stays on!!! Anyone got any ideas??
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Only thing I can think of is you may have damaged it and it is providing an inacurate reading which is affecting the emmissions as thats what the orange engine light indicates.
    The Boost sensors are quite fragile and easily damaged - assuming you are talking about a CDTI 150?
    GazZA4
    Insignia VX-Line Nav CDTI 170.
    Jun 2009
    Chelmsford
    Yes its a 05 CDTi 150, only sprayed it with carb cleaner and a very gentle rub with a tooth brush
    Regular Member nick_s's Avatar
    Jul 2009
    Stoke on Trent
    Is the plug connector properly attached? I reckon you've cross threaded the bolt if you can't get it back in properly.
    Sep 2009
    Glasgow
    done this many times and touch wood , had no issues.
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Quote Originally Posted by Governor View Post
    i would persume that due to not being able to tighten torx screw up it is not sealed in and got a poor fit so giving off a inacurate reading???
    Hanging Heaton / Batley
    14 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    As above, if the bolt wont tighten its not on right. remove it and put it back on...
    Regular Member djr69uk's Avatar
    Midlands
    i left my boost sensor to soak in carb cleaner then sprayed it directly. didn't use any brushes or anything. as previously stated they can be a be fragile.
    the bolt to secure it shouldn't cause any probs. it's just to secure it properly to the manifold - it wouldn't cause EML unless the sensor itself is loose. i'd remove and refit the connector though.
    also, have you cleaned EGR valve? might be an idea to do this as well. might be the cause of the original problem.
  1. cleaned dpf but now got no boost
    By daz_scooby@hotmail.c in forum Engine & Drivetrain
    Last Post: 4th October 2012, 20:30
  2. Just cleaned my boost sensor
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2011, 19:43
  3. egr/boost cleaned
    By tomo610 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 13:19
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
  5. EGR VALVE and BOOST SENSOR cleaned today!
    By VXR CDTi in forum Engine & Drivetrain
    Last Post: 11th November 2008, 23:20
