Thread: power loss
    kent
    Unhappy power loss
    hi ive just gor a vectra sri 2.2 dti drives realy nice at normal raod spead but some times when i put my foot down for fast accelaration in 2nd and 3rd it picks up speed realy fast then the power just goes dead if i keep my foot down it picks up again it a 2002 vectra
    Regular Member CDTi-SRi-Matt's Avatar
    Nottingham
    How long does it go dead for? my CDTi does this sometimes just before the turbo kicks in, only when my foot is right down though. Its like ive caught the turbo by suprise and its not ready or something. Only dies for a split second though.
    kent
    it only dies for about 2 to 3 seconda then the power comes back
    Bristol
    Vehicle : CDTI 150
    Gents, try cleaning the boost sensor.
    Basically the MAP (manifold absolute pressure) sensor detects a sudden drop in pressure and lets the ECU know that the demand from the engine has suddenly increased e.g. when accelerating.
    There is a how 2 thats applicable to both as they use the same boost sensor.
    Try this if it doesn't work get back on
    kent
    thanks i will try that today let you know if it works
    Regular Member Fash's Avatar
    Doncaster
    Would cleaning the egr work on a dti too or don't the have one that clogs up like our cdti's do ? lol
    kent
    i cleaned the mas flow sensor seems to run alot smoother only problem is the spanner is on i get code 0103 now how long till it resets or how to reset
    Bristol
    Vehicle : CDTI 150
    Quick reset is with OP Com or Tech 2.
    Could disconnect battery for about 30 mins but make sure you've the radio code.
    Of greater concern how did you clean the MAF. At best a quick spray with Iso propyl alcohol or brake cleaner, shouldn't actually touch the wires etc
    kent
    just used cotton buds didnt touch with anything else . what is tech 2 also wher is the boost sensor un 2002 sri dti not sure what im looking for
    Bristol
    Vehicle : CDTI 150
    Tech 2 is the dealer plug in computer.
    Boost sensor is located as follows.
    Remove engine cover As you face the engine on the front right hand side you will see a thick black pipe, this joins a silver manifold. Just after the join and to the rear of the manifold is the boost sensor, thers an elec plug and its held in with 1 bolt. Will need to gently wiggle it out as it has a seal on it.
    DTC p0103 is MAF sensor high input. Could be the MAF or wiring
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. loss of power
    By STRETCH2009. in forum Engine & Drivetrain
    Last Post: 8th August 2012, 18:44
  3. Power loss HELP
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 28th July 2012, 12:34
  4. 2L DTI '53 Loss of Power
    By BigTunz in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 17:27
  5. loss of power
    By philly in forum Engine & Drivetrain
    Last Post: 11th May 2009, 07:21
