Results 1 to 9 of 9
Thread: Acceleration sticking...
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    Default Acceleration sticking...
    Hi all
    difficult one to describe...ill try.
    When driving normally or on the motorway i find that my acceleration sticks, meaning the revs fly up and the car doesnt go as fast as the revs show. Releasing the accelerator and pressing the pedal again slower brings it back to normal, this is a pain when trying to get off a slip road on the the motorway to say the least.
    Any advice?
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Sounds like slipping clutch to me. Some folks have had issues with the clutch pedal not returning properly. Next time it does it, stick your foot under the pedal and see if it lifts up at all.
    There is, I think, a mod kit available with a stronger spring.
    Phil
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    defo sounds like the clutch mate
    Nov 2007
    Leeds
    cheers chaps ill try it after work and see what happens....will post findings
    Nov 2007
    Leeds
    doesnt appear to be the clutch pedal thats causingt he revving while acceleratin....so slipping clutch is there a cheap solution to it?
    Get a new one...?
    Regular Member paz_badboy4life's Avatar
    Leicestershire
    Vehicle : Vectra SRi Dual Fuel NAV
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Quote Originally Posted by arkhan78 View Post
    got a new clutch fitted last week. £350 all in. i had same symptoms as u. to make sure ur clutch is gone. start the car, pull the handbrake up tight, whack it into 4th gear, lift up your clutch smoothly. if it doesnt stall, then u need a new clutch. and i would advise to get it sorted asap. i left mine for a week before i got round to doing it, it works its way from 5th gear to 4th to 3rd to 2nd and last but not least 1st. and then u truly are fooked!
    PaZ!
    Nov 2007
    Leeds
    did the 4th gear clutch test and the car stalls as normal as the clutch is lifted to the top.
    Is there anything else i can do to test or if i take it into a clutch specialist will they be able to check and diagnos?
    May 2008
    Derbyshire (south)
    There is a chance that there maybe some adjustment left on the cable, to get a bit more bite, but it won't last much longer, best to just get a new clutch assembly, as, has been suggested, sound's like you'll be struggling to get it uphill, or even off a junction briskly very soon
  1. sticking
    By HARRY SRI in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2012, 22:23
  2. sticking egr?
    By chris1804 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2010, 20:01
  3. Bonnet sticking
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 18:59
  4. Sticking Auto Box
    By Gersh in forum Engine & Drivetrain
    Last Post: 26th December 2008, 10:47
  5. Sticking Wipers
    By Nerm in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2007, 15:57
