Thread: Over heating
    South Wales
    Default Over heating
    Ok so basically I don't think my cooling fan is working I checked the fuses and they are fine. When I'm driving it gets hot an the coolant starts to steam out in a massive burst and then the coolant tank is empty ad the no coolant light comes on any ideas???
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    When you drive does the temperature rise up then fall dramtically then rise up till its overheats if not then the thermostat is the likely culprit by not opening and not allowing the water to circulate properly, it works like this to warm up the engine more quickly or it could be the water pump when its hot if you try and open the expansion tank cap is it pressurised? if so the pump is probably ok.
    South Wales
    Yea it's pressurised. The temperature gauge seems to be ok it doesn't fluxuate in temp it just keeps rising so it's probably the thermostat..... Is this something I can change myself?? Couldn't find a how 2 on here :'(
    23 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Yes you can do it yourself easy job and if you take pictures you could post a How 2 they cost about £50 for the housing with the thermostat in them but some members have changed just the thermostat for about a tenner.
    South Wales
    Haha I could if I knew where the thermostat was!!!
    South Wales
    Can anyone provide me with a picture or some advice for where to find the thermostat and how to change it please
    South Wales
    ok...........opened the tank while it was hot after driving about 20 miles.........no pressure........now im totally confused please please please can someone help with this as i've already plughed £500 and god knows how many man hours into this car and im starting to loose hope (only had her like 2 weeks!!)
    23 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If there's no pressure it could be the water pump you are gonna need to have it tested mate at a garage before this overheating causes some serious damage like the head warping.
    South Wales
    yea i'm gonna take it down my mates he can pressure test it for me (works from home mechanic)
    Quote Originally Posted by BaileySRI View Post
    You really shouldn't be opening the coolant cap with a hot system, the water simply boils and ejects itself so it's no surprise it is empty afterwards
    However, once empty the coolant warning light may come on, but only if your car has the computer warning system (otherwise known as driver information centre)
    If there is steam coming out of the sealed system when the engine is wamr or hot then the breakage needs to be sourced AND quickly
    When the engine cools down (without removing the cap) can you hear any gurgling noises?
  1. heating... :(
    By jay14 in forum North East RO Vacant - ARO - Vacant
    Last Post: 25th February 2013, 19:14
  2. No Heating
    By bigmac in forum The 'Off Topic' room
    Last Post: 16th November 2010, 01:08
  3. Over heating???
    By lukesignum in forum Engine & Drivetrain
    Last Post: 16th June 2010, 17:44
  4. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  5. heating
    By dar in forum South Wales (RO - Vacant)
    Last Post: 30th December 2009, 19:36
