Thread: Dump valve and Induction Kit worries.... Help
    Regular Member dawasdave's Avatar
    Norfolk
    confused Dump valve and Induction Kit worries.... Help
    Hi all.... After getting All excited as my forge D/V kit turned up this morning i thought i would set about fitting it.... Only to find my car seemed a little different to ones i have seen on here..... Mines a 57 plate 2.0t and the Blanking Plate holes would not line up.... Plus there was No gasket either when i to the recirc valve off Did they change the design on the later cars....???
    Any way its gonna have to be sent back as it wont go on so im now gonna look at Induction Kits instead to give a bit of a better sound..... What are you recommendations as the only one i can find is a K&n 57i..
    Please help a Neebee lol...
    Dave
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    K&N apollo if you can bare the cost as it has a direct cold air feed or if K&N 57i or simlar, get a heat sheild made to reduce warm air from engine bay being pulled in, i am sure you can get pipercross etc though
    hth
    Midlands Mod Shop - NFFC.
    Norfolk
    Cheers bud... When i search for a kit fo rit the only one that comes up is the 57i...
    No ideas why the DV wouldnt fit then ??? im gutted.......
    Trim : Get a
    have no experiance of dump valves i'm affraid...not sure how many folk on here actualy have them fitted either...
    http://www.thepipercrossshop.co.uk/i....asp?model=159
    give these a call with your engine spec i am sure someone has one fitted
    http://www.demon-tweeks.co.uk/produc...010&tlgrp=R010
    hth
    Norfolk
    Cheers for your help bud.....
    Trim : Get a
    no worries
    Regular Member jlock's Avatar
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Engine : 2.5l Straight 6
    I got a bmc cda induction kit on mine. I got it cheap 2nd hand off ebay.
    Its best to get a closed induction system such as mine, the k&n apollo or the pipercross viper etc... As the open air cone ones dont agree with some engines i dont think, unless this would be erradicated with the heat shielding, but i wouldnt know
    My bmc does make a nice noise when you pop the foot down though
    Norfolk
    Sounds ace mate... Just wish i could find a closed one.... Grrrrrr lol...
  1. dump valve
    By chrosty in forum Diesel Engine related
    Last Post: 15th September 2010, 00:29
  2. Dump valve For 2.0T!!
    By stev26gray in forum Petrol Engine related
    Last Post: 13th February 2010, 23:48
  3. Replies: 23
    Last Post: 6th March 2009, 09:00
  4. dump valve
    By ant_cdti in forum Diesel Engine related
    Last Post: 19th July 2006, 22:23
  5. dump valve
    By jayzee in forum Engine & Drivetrain
    Last Post: 24th May 2006, 13:38
