Results 1 to 10 of 17
Thread: LCD Display Part Number
    Staffs
    Default LCD Display Part Number
    Hi Guys,
    New to this forum!!
    I have a 2004 SRI with the full size display between the air vents.
    Last week the screen started to break up and is slowly getting worse, so I need to source a replacement, I guess via vauxhall is the expensive way?
    From what I understand there are 2 types of display the standard one with the time and date buttons below a narrow screen and a full size screen with the controls on the indicator stick??????
    I have the full size display unit and was wondering if anybody knew the part number and where I can get them other than vauxhall?
    Thanks for the help.
    Oct 2009
    lincoln
    i have one if ya interested?
    Full Member paul.sessions's Avatar
    leighton buzzard
    i would take it apart and look at the two ribbons what go into the screen, top and bottom these being loose or coming off could cause this problem quite easy to do too.
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    There are several different displays from the BID to the GID to CID and they are different between facelift and pre-facelift (full or half canbus in simple terms) and you have to get the right one. If you remove the vents and note the part numbers and get a match for it. For pre-facelift half canbus it shouldn't need Tech 2 and will therefore be plug and play. The easy way to check half canbus (6 buttons on the steering wheel 3 aside) and full canbus 2 buttons and a scroll wheel each side and the CDC range of head units.
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you post up the two letter Alpha Code on the back of the display, we can then advise more accurately.
    Although you say yours is a 2004 model, this is slightly confusing, as the cars moved from half can to full can around October 2004.
    If yours is half can, then as said you will have buttons on the steering wheel (3 on each side) and your radio would have a letter prefix of NCDC, NCDR, CCR or CDR.
    If yours is full can, then you will have scroller wheels and buttons on the steering wheel
    (1 scroller wheel and 2 buttons each side of the steering wheel).
    Radio types are CC20, CD30, CD30 mp3, CDC40, CDC40 Opera, CD50, CD70 Navi.
    More info the better please...
    Staffs
    Thanx for the input.
    I didnt realise there was such a vast variety, my Vectra was first registered March 2004 and is pre-facelift, 3 buttons on each stick and the CD player is a CDR model. I was hoping I could find a serial number with out stripping it out first.
    Hopefully this additional info may narrow it down??
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Any pre-face GID will fit so if yours is one Andy then it will be fine,all though you may need tech2 to enable BC as its the GID that holds the information and not the stereo as not all GID's are BC enabled
    Irmscher Insignia CDTI 130
    Staffs
    I may seem simple here but its almost like your talking in foreign tongues
    Can I ask what GID, BC & tech2 mean?
    Oct 2009
    rhyl
    BC i think is the small screen,your screen is GID and CID being a colour screen,if your car has 3 buttons on either side of the steering wheel its half canbus,and tech 2 is a computer that plugs into your car and will enable your computer stalk to work with your GID if not already enabled,
    Oct 2009
    lincoln
which plug is for 2007 vectra lcd satnav display
