Thread: Snowfoaming
    Blantyre
    Default Snowfoaming
    Can i blast the engine bay with this and then jet wash off, or am i likely to damage some electrical stuff in there
    swansea
    Don't even think about it!
    I've seen Mav do this loads of times - I think he jsut takes up the obvious electrical connections first then away he goes...
    http://www.vectra-c.com/forum/showth...nowfoam+engine
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Snowfoam wont remove oil and grease so I wouldnt bother. Use some proper engine degreaser or the Megs Engine cleaner then the Megs Engine dressing as it works very well and looks nice afterwards
    Blantyre
    OK ta
    Cambridgeshire
    I tried the snowfoam on mine a little while back and as above it doesn't really work.
    I use Megs APC, some good stuff and does the trick
    Edinburgh
    I did this on my Astra, think the stuff was called Gunk or something. Do it while the engine is running (it gets wet anyways) and just cover important electrical stuff with plastic bags.
    Leicester
    Quote Originally Posted by jrh1 View Post
    Why? I do mine very 4-6 months, and have done on all 4 of my 1.9 CDTi's and my 3.0 V6 CDTi. Never had one fault.
    I don't cover anything up either. The electric systems these days have to conform to IP67 water rating. Which actually means the part protected to IP67 can be submerged up to 1m for a maximum of 1 minute.
    So snowfoaming and blasting off the engine bay with water will cause no problems what so ever.
    Leicester
    Quote Originally Posted by parsco View Post
    Your right, it's no good for removing oil and grease, but if everything is working well, there should'nt be any lying about
    What it is good for though, is the general road muck and dust that builds up.
  1. snowfoaming??
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2012, 20:42
  2. What is snowfoaming
    By chuckleuk in forum Detailing and Car Care Discussion
    Last Post: 29th August 2010, 20:02
  3. you tube vid of me snowfoaming the vectra
    By big rich in forum Detailing and Car Care Discussion
    Last Post: 23rd March 2009, 13:10
