Thread: Spring Mod - Is This Correct (pics)
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default Spring Mod - Is This Correct (pics)
    Probably a stupid question but this is how they go on, correct?... seen pics with the slits facing inwards rather then up - if i make sense...
    I've used the blue ones (still got the green), green seem a little thin, are they for standard springs?!?
    Cheers all...
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Are these needed on aftermarket springs or is it just for Vx springs/struts?
    18 Post(s)
    Mileage : 110k
    Think they benefit all, if you've had creaking. suppose its better then just copper greasing them and hoping that will last...
    Mar 2007
    Southport
    You're probably right - Isn't there's a mod for the top of the spring too?
    18 Post(s)
    Mileage : 110k
    Quote Originally Posted by Ian S100 View Post
    Already a rubber pad in place up top, this is just to stop the metal on metal contact on the bottom...
    Mar 2007
    Southport
    I'll be doing my springs / struts etc next weekend so I'd best get some - are you replacing any of the bolts?
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    needed on all vectra front springs, forget to fit then or chose not to and trust me the noise when turning will drive you crazy then its a strip down job to put them back on. they should just pull off the bottoms of your old springs if you dont fancy paying the 3 quid from the stealers for some new ones
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    There are two wire thicknesses on the springs, i'd say that the thinner ones are for thicker springs
  1. Is this the correct Kit?
    By Vectra Dan SRi in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2013, 00:07
  2. is this correct
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 14:15
  3. correct oil
    By Dougb in forum Engine & Drivetrain
    Last Post: 27th April 2010, 14:27
  4. spring seat mod pics
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2010, 18:37
  5. PI spring pics request...
    By danBoy in forum Styling
    Last Post: 27th January 2008, 17:20
