Results 1 to 10 of 13
Thread: some probs cooling system
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default some probs cooling system
    i just bought a sri 120 05 44000 miles, but haveing probs, the temp hand will not rise at all, so i got a new thermostat, not fitted yet but when i was looking at the expansion bottle i notcied the mixture was very weak hardley no antifreeze in at all would this affect the tem gauge, if i have to fit the thermostat i will be changing the coolant, very strange that all this cold weather and very little antifreeze in the bottle.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    the weak antifreeze wont affect temp guage most likely be thermostat changed mine last week made a big difference.
    hull
    could be faulty temp sender usually located within the stat, unsure on cdti.
    alot of people just top up their bottle with just water and over time becomes really weak, although this wouldn't stop your temp gauge moving.
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    the only thing thats worrying me is why the mixture is so weak something must have happened to cause this.
    hull
    Split rad hose, leaking rad.
    I wouldn't worry too much pal, mine was the same when i got it 54 reg 1.8sxi. top my coolant up every 3/4 weeks.
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    no leak collant level fine just found it strange that the coolant was very weak
    Full Member Big Sig's Avatar
    You just bought it? I expect the last owner just cut a few corners, you may never find out why.
    shropshire
    HI.
    I've just recently bought a CDTI 120 (54 plate) where the temperature gauge hardly moves of cold at all even after half an hours driving. Heating seems fine to me as well as overall performance.
    PRESTON
    hey, i have a 55 plate CDTI 120 Design. Had the same issue, temp gauge needle never moved off cold and it took ages ages for the heater to get warm, changed the stat, pig of a job on the 120, allow yourself a couple of hours, gauge now reads about 85 and heater toasty. New stat and two litres of antifreeze in the coolant, should see ya right.
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    would i have to flush the cooling system or just drain the header tank
  1. Cooling system help
    By Tinks in forum South Central (ARO - matty2fatty)
    Last Post: 11th December 2012, 21:37
  2. cooling system problems
    By vmb2722 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th July 2012, 19:59
  3. Cooling system
    By Tinks in forum Engine & Drivetrain
    Last Post: 21st April 2012, 10:43
  4. Cooling system performance fault
    By brianjamesreed in forum Engine & Drivetrain
    Last Post: 4th July 2009, 08:22
  5. cooling fan probs
    By abyh in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2008, 13:43
vectra c how to drain cooling system
