Results 1 to 10 of 22
Thread: Climate control
    Jan 2010
    Liverpool
    Default Climate control
    After having my Elite for a day, I've noticed that the fan on my climate control doesn't appear to blow as hard as the Mrs' SRi manual system.
    For instance, if I use the front demist button on both cars, the SRi is clearly better than mine. You can't hear yourself think the blowers are that loud.
    Also at maximum (7 I think) and the blowers set to front exit its not really very strong. Whereas the SRi would make my eyes water!
    Do I have a problem, or is this just a characteristic of the climate control system?
    Regular Member no1golfer's Avatar
    Jul 2009
    newcastle upon tyne
    i have the elite also and find its like your wife's car,very loud and blows you away.may need a re-gas or something,i think kwik-fit or national do a free check.
    Pollen filter blocked? It could be restricting the air flow.
    Mileage : 000
    Mine blows hard and fast too. Is your pollen filter blocked up with "muck" I wonder if a restricted inflow of air would cause this "effect". Also when you manualy turn the "big" central "knob" up to full blow doest that make any difference from say speed 3. You can manualy adjust the fan speed with the central "knob" this might give an indication if the fan is working proporly.
    I would check the drain holes by the pollen filter to see if they are blocked whilst you are "looking" at your motor, as if water gets into the heater motor or resistor pack it can cause problems.
    Jan 2010
    Liverpool
    I'll have a butchers at the pollen filter in a bit, will report back with findings.
    Jan 2010
    Liverpool
    Had a quick look.
    Pollen filter. (I think it needs replacing lol)
    Is this the drain hole? It was full of gunk.
    Jan 2010
    Liverpool
    Quote Originally Posted by ed taylor View Post
    Turning the big knob does mke a difference yes.
    When I use the recirc button it does apper to blow much faster. It just sounds like its muffled inside the dsh somewhere when changing airflow about. There is a definate sound as if motors that change the flow are working, though.
    Mileage : 000
    The filter could do with changing.
    Yes that is the drain hole. Give it a clean out to be on the safe side.
    With the filter out. Try pressing the front screen demist button see if the "blow" is as strong then. Or stronger. If it is stronger as it should be then it will point to a bolcked filter restricting the incoming air.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    good job you cought the blocked drain
    Jan 2010
    Liverpool
    If I put recirc on, turn the fans up and set airflow to auto they can blow pretty fast. When I press the demist button they slow down. When I turn the demist off they speed up to what they are like on the Mrs' SRi, then slow down a little again.
    Wierd eh?
  1. another climate control
    By Даниил in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 19:43
  2. Climate control and GID
    By Ben_ in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2011, 19:30
  3. climate control
    By stu_c in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 18:27
  4. Climate control Help
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 00:23
  5. Climate Control
    By liphook in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 04:10
