Results 1 to 10 of 14
Thread: Struggling at 1st base
    Regular Member beethamwest's Avatar
    Jul 2009
    Liverpool
    Default Struggling at 1st base
    How on earth do i remove my front pre-facelift fornt lights.
    Having removed the 2 visible screws, there is something that i cannot reach keeping it on?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep there are some behind the front bumper
    Dunstable
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    as above, am i rightin saying that if you undo the small torques in the wheel arch liner, then undo the bolt that fastens the corner of the bumper to the inner wing, then the bumper should flex enough to be able to get to the last bolt under the headlamp?
    Jul 2009
    Liverpool
    Yeh 1 of the torx screw on each arch is rounded off, the other 2 come out but there is 1 on each that i cannot unscrew, as it is rounded
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by beethamwest View Post
    long nosed small mole grips should sort that,mine were the same
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    You can do it without removing the bumper, bit of a pain but I managed! Just undo one side of the bumper and you can just get at the other torx's, gotta push the bumper down a bit at the same time though! Just remember when you've removed one light, re attach the bumper at the side you removed the light from to keep the bumper on.
    Regular Member jlock's Avatar
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Engine : 2.5l Straight 6
    After reading the title I was expecting a 'personal' question
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by Danialj32 View Post
    hmmmm as said above in the thread
    Jul 2009
    Liverpool
    Got one side off. my drivers side wheel liner has always been ripped almost right up to the top torx, so i had to rip ot that bit further
    Anyway lights work in the connections that wa sshown in the how 2 guide, just hope the mole grips sort the other side
  1. Struggling... need some help please...
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2007, 12:53
  2. Struggling to understand.....
    By thegoldenbullet in forum Diesel Engine related
    Last Post: 25th March 2007, 08:51
  3. struggling badly
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2006, 19:06
