Results 1 to 10 of 21
Thread: Front strut torque setting please help
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Front strut torque setting please help
    guys doing the springs at min and need the torque setting for the bolts at the top of the front shock towers? i knowe its tight then a degree setting but i cant remember exactly
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Suspension Strut piston rod nut 100 nm
    Mar 2007
    Southport
    Suspension Strut upper mounting bolts 20 nm + 45 degrees + 15 degrees
    Aug 2007
    Lisburn, N.Ireland
    no i mean the 3 that hold the top of the suspension onto the car
    Aug 2007
    Lisburn, N.Ireland
    great
    Mar 2007
    Southport
    Posted it twice for some reason
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Mar 2007
    Southport
    must be a regular job
    Aug 2007
    Lisburn, N.Ireland
    lol thanks for your help guys. i tried looking for that post john but couldnt find it. lol all sorted now well hapy
    Mar 2007
    Southport
    Did you use the original bolts or replace them with new ones?
  1. Torque setting... strut to hob bolts
    By megsdad in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2013, 20:36
  2. Torque setting
    By shaun.b in forum Engine & Drivetrain
    Last Post: 11th December 2012, 20:46
  3. Torque setting for front hub nut?
    By Craig1985 in forum Suspension, Wheels & Brakes
    Last Post: 1st May 2011, 19:21
  4. Torque wrench setting
    By damers2000 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 11:07
  5. torque settings for front right strut please
    By gotlosi in forum Suspension, Wheels & Brakes
    Last Post: 24th April 2009, 11:05
https:www.vectra-c.comforumshowthread.php102452-Front-strut-torque-setting-please-helppage2
vectra c strut torque settings
strut mount bolt torque vectra
torque wrench setting front struts car
2001 vauxhall vectra strut torque
bolt for strut missing vectra c
when changing vectra c struts do they need torqued
