Results 1 to 10 of 11
Thread: rear door handle
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default rear door handle
    my rear door handle will not spring back into place when you pull it out it stays out i have the door card off but a cant see what im supposed to try and fix anyone got any ideas
    Trim : SRI
    Mileage : 46000
    forgot to say the handle is not even tight to pull out
    Dunstable
    Round the edge of the door near the catch, is a rubber grommet. Behind this is a torx screw, maybe this has come undone. Try doing it up as this is what you use to remove the handle. When you pull the handle and undo this screw, the handle stays in the out position, so try doing it up...
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    look in the how2 section its coverd there..
    Trim : SRI
    Mileage : 46000
    Quote Originally Posted by Ademusic View Post
    already tried that any other ideas
    im starting to panic cause it up for mot on monday
    Dunstable
    Can you shut the door? If the door doesn't stay shut, whatever you do don't lock the door whilst pushing it closed, I did this when removing my handles on my old veccy, and when I unlocked it there was no way of opening the door, was a fiddly job to sort out...can you push the handle back in?? Sounds like a spring has gone or something....difficult to say without seeing it..
    Trim : SRI
    Mileage : 46000
    yes the door shuts ive already closed it and it locked that took a while to get open again. im trying to see if the spring is not working cause the door opens too easy theirs no spring back from the handle...
    Dunstable
    Don't know what else to suggest. Is the interior handle the same? Could be a problem with the actual catch rather than the handle. I've been searching on here to see if anyone else has had this problem, If I find anything I will post it on here for you..
    Trim : SRI
    Mileage : 46000
    the inside handle is fine i have looked in the other posts and cant find anything thanks for the help :-)
    Regular Member coolcat's Avatar
    Feb 2012
    bolton
    Vehicle : vectra
    Trim : sri
    Engine : 1.9 cdti 150
    Year : 08
    Mileage : 72000
    hi mate did you get your handle sorted as i have the same problem thanks.
  1. LED door handle mod ( outside )
    By bobsimes in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2012, 13:30
  2. help with door handle
    By shoota70 in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 14:46
  3. Problem with rear door handle
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 21:33
  4. OSR External Door Handle & OSF Door Lock
    Last Post: 29th May 2009, 17:14
  5. door handle
    By decks in forum Bodywork & Interior
    Last Post: 17th June 2008, 12:05
