Thread: Clutch won't disengage
    May 2006
    Mansfield
    confused Clutch won't disengage
    Well I got in this morning and pressed the clutch pedal down, turned the starter and the car lept forward. Depressing the clutch it feels very light to start then gets firmer towards the end of its travel. Any ideas people before I start grovelling under it or do I just call the garage ?
    SJ
    Regular Member maccc's Avatar
    scotland
    Could be your cable but then again you would have felt that go, Not sure mate.
    May 2006
    Mansfield
    Quote Originally Posted by maccc View Post
    Thanks for your reply, however it's a hydraulic clutch.
    SJ
    Vectra has never used a cable, always been hydraulic
    If the clutch pedal will not operate the clutch, then it really needs to be attended to by a mechanic
    Ironically, normally it's the other way round, the clutch won't engage
    Stockton on Tees
    The Vec can still be driven with no clutch. Only problem is stop starting, but just pull it into neutral then when ready to move again just push gearstick towards first and hold it there till it engages. Then just change gear when you hit 2500rpm by releasing accelerator then pull/push the stick firmly into next gear slot. Not advisable for long periods though.
    May 2006
    Mansfield
    Thanks everyone,
    Problem diagnosed courtesy of the wife, I got her to push the pedal down while I looked around, Brake fluid level dropped about 1mm for every pedal push - so it's off to my local garage for a new actuating cylinder and while he's got the gearbox off a new clutch ? (done 60k on the original)
    SJ
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
  4. clutch
    By Desulph in forum Engine & Drivetrain
    Last Post: 18th August 2008, 07:26
