Results 1 to 10 of 18
Thread: Fuel filter on a 3.2v6
    Oct 2009
    newport
    Default Fuel filter on a 3.2v6
    Just out of interest how easy are these to change or is it worth leaving to a garage?
    Regular Member killer_bunny's Avatar
    Jan 2010
    leeds
    im interested too if anybody knows?
    Nottinghamshire
    The fuel filter is just a cartridge in the fuel pipe coming out of the offisde of the fuel tank - it's not under the bonnet so it fits in the same way as any other petrol Vectra. Take a lookunder the car and see if it's a job you think you can do seeing as there's no dismantling involved to see what needs to be done.
    There's a quick-release clip on the 2 pipes that need to be undone - the proper fuel clip pliers work best, but you can use a small screwdriver or something to release them. Then just take the old filter out and put the new one in noting the direction of fuel flow and fitting it the right way round (look for the arrows on the new fuel filter casing). Finally re-connect the 2 pipes ensuring they clip back in place properly.
    Before you start you are supposed to release the fuel pressure, but I don't know if this is really necessary, or how it's done on the 3.2. I'm sure someone will be along shortly who knows...
    They don't say they need to remove the pressure but they do use a tool that drills a hole in the filter whilst containing the running fuel, so that maybe how they get away with it.
    Nottinghamshire
    Good idea, but you would have to be very very very careful not to create a spark or heat if trying that at home!
    You're perhaps OK without releasing the pressure as long as you are prepared form some spray as well as some spillage.
    Its a special tool they use, not so much a drill but a canister with a sharp point I think.
    Nottinghamshire
    That rings a bell now you say it. I guess the 'proper' Vx tool is designed not to create any sparks or any heat.
    I guess a DIY-er could try something similar while being careful to avoid sparks and heat.
    Essex
    Quote Originally Posted by James24 View Post
    Exactly the way i did it on my Omega!
    To release the pressure in the fuel system all you do is start the car and pull the fuel pump fuse. After a few seconds engine stops as no fuel and no pressure in the system.
    Assume you can do the same on the Vectra/ Signum
    BUT there will still be fuel in the filter so becareful when removing
    Mileage : 000
    I have never used the "special" tool. Just be carefull not to brake the clips. But I get the clips just in case. There will be a small amound of fuel loss so a tray or something to catch it in is a good idea.
    Jan 2010
    leeds
    cheers guys very helpful :-) only question i have, my mate mentioned today that i need to clamp the fuel lines either side of the filter before i take it off to prevent fuel seepign everywhere, is this the case of should no fuel leak as the engine is off (except the small amount in the lines)
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Fuel filter help
    By wolvesdaz in forum Engine & Drivetrain
    Last Post: 4th March 2011, 10:47
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  4. fuel filter
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2007, 23:27
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
vectra c 3.2 v6 fuel filter
