Thread: Rear pads
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default Rear pads
    Hi all, just changed my rear pads which went fine but
    have noticed my handbrake seems to need pulling up
    higher to get it to work ! i would of thought it should
    operate with less pulling ! ! if you see my logic ! do i
    need to adjust anything ?
    cheers
    Kcs
    Regular Member nokiaman1978's Avatar
    Sep 2009
    Glasgow
    think the handbrake is self adjusting by holding brake pedal and pumping handbrake, sure i heard this but will probably be wrong..
    Regular Member Vectra_C_Chris's Avatar
    May 2009
    Perth Western Australia
    Correct nokia.
    When I changed my pads I had to pump the brake a whole lot. Then pull the hand brake until it feels like it used to. IT WILL re-engage.
    Bleeding the brakes will help.
    Regular Member kentish_bloke's Avatar
    Mar 2008
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    the advice i found on here was, once youve changed the rear pads, DO NOT depress the brake pedal before applying the handbrake a few times after youve lowered it off the jacks.
    the handbrake MUST be applied several times as this adjusts the mechanism. if you use the brake pedal before doing this it can hamper the automatic adjustment.
    the above worked for me, but i stand to be corrected on the method.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    It will sort itself out, it adjusts itself. Mine was exactly the same, now 3 clicks and holding perfectly.
    Dec 2007
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by kentish_bloke View Post
    THIS IS CORRECT!!, the hand brake should be applied repeatedly 'before' the foot brake! , hold the button in & work up & down as many times as you wish this will adjust the handbrake mechanism then use as normal this is the right way & will reduce/eliminate damage.
  1. which rear pads for a 3.2?
    By andyxedos in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 19:05
  2. Rear pads
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 07:29
  3. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
  4. Rear Pads
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2007, 18:02
