Thread: 2.2DTi brake disc size upgrade and shock and spring replacement
    Jan 2010
    Liverpool
    Default 2.2DTi brake disc size upgrade and shock and spring replacement
    I'm looking to change my discs and pads on my 2.2DTi.
    Would I be right in saying that if I wanted to fit the larger discs from the GSi or 3.0CDTi I would need different caliper brackets? If so, does anyone have part numbers to hand, please? The rear discs also come in a vented option, would I need a wider caliper?
    Also, I'd like to lower the car as its an Elite and handles like a barge. Can someone please point me in the right direction to affordable springs and shocks, or could I get away with just springs and keep the Elite shocks?
    Any help will be greatly appreciated.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    In answer to 1st question to fit the larger 314mm discs you will need the calipers and carriers as well because the calipers are bigger, the standard rears on the DTi are ok.Most people with the DTi's just go for the bigger 314mm conversion as they seem underbraked at the front. HTH (im sure others will be along to advise you)
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Tbh mate I wouldn't bother going any bigger than 302's. Those were fitted to the early V6's and all of the 2l turbo Vecs. I've had them fitted to mine for about 6 months now and they feel great with plenty of stopping power. Also as they aren't as sought after the prices are pretty cheap too.
    If you wanted that bit more power from them fit them with EBC groove dot discs and green stuff pads
    As for shocks/springs if you are looking to stiffen it up a bit then I would fit eibach springs with bilstein b4 shocks. You could just do the springs if you wanted but you'd probably find it a bit soft still.
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    ive got the elite and i just fitted the eibachis springs andit did tighten thing up but the ride is still good . khalid
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    I have done a few upgrades and will be doing the brakes soon. tbh i think the braking is poor on my car, thats even after i have fixed them!
    Jan 2010
    Liverpool
    Will I need different calipers and carriers for the 302mm discs?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Sorry yes you would mate
  1. Brake Disc Size
    By hodge725 in forum Suspension, Wheels & Brakes
    Last Post: 2nd November 2012, 17:41
  2. Brake Disc & Pad Replacement
    By robdd1 in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2010, 14:06
  3. Brake disc replacement
    By CrisA in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2010, 14:06
  4. Brake disc size?
    By joe2187 in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2009, 21:22
  5. Brake Disc Size...
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2008, 21:22
vectra c 2.2 dti brake disc size
vectra c 2.2dti brake disc size
vectra c 2.2dti brake disk size
