Thread: 2.2 dti
    Horley
    Default 2.2 dti
    HI I have a 2.2 dti elegance auto, the temperature gauge takes about an hour of driving to move at all, the heater warms up quite fast, once the gauge has moved up after about one hour it seems to stay there, when I go on any short trips it stays right at the bottom and does not move although the heater still gets warm. Any ideas or advice gratefully received
    Regular Member paul.sessions's Avatar
    leighton buzzard
    yep diesel engine take a lot longer to warm up than petrol
    Jan 2010
    Liverpool
    The two 2.2 DTi's in our household are similar. They take a fair while for the temp gauge to move.
    One is a 53 plate with roughly 83k miles covered, the other is an 03 plate with 126k miles covered.
    Regular Member muzmayhem's Avatar
    Jan 2010
    North Angus, Scotland
    I have a 2.2 dti elegance manual 53 plate & mine takes a good while to move as well. Just the nature of the car.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Patch
    taking an hour is not normal it sounds like you have a faulty sender unit,as the lads say diesels take a little longer to warm but not that much.gauge should be on the move within 2 or 3 miles.
    leighton buzzard
    i travel 7 to work and it never moves.. takes a bit more than that to get it to move..
    n.ireland
    Quote Originally Posted by pach1962 View Post
    hi mate try an ect switch (engine coolant temp sensor) around £14 inc vat from the dealer
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If the thermostat is OK the DTi will warm up quite quickly. As said 2-3miles should make the guage move a bit and it should be up to operating temperature in 10 miles or so.
