Thread: Fuel filter plug?
    Jun 2009
    Kent
    Default Fuel filter plug?
    Anyone know what the electrical plug does on the top of the fuel filter ?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I would stab at a guess its for the pumps to pump fuel out of filter house
    Irmscher Insignia CDTI 130
    Nottinghamshire
    I guess that's a picture of a fuel filter on a DTI. If so, it's the connector for the fuel heater which is built into the fuel filter. The pump is a great big thing driven off the engine chain, so it's not that!
    On a CDTi, there's a similar fuel heater connector in the top of the fuel filter and also a connector for a water sensor on the side of the fuel filter. The DTI's fuel filter doesn't have a water sensor.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    It was a stab in the dark should of checked my haynes manual lol
    Jun 2009
    Kent
    Thanks James24 yes mate sorry for not telling you the model 2.0 DTI been having terrible problems with the P0400 code EGR Valve flow and found that this plug was disconnected would it cause a problem with the cold we have been having?
    Nottinghamshire
    Quote Originally Posted by reesteod View Post
    It won't be helpng. The heater warms the diesel up as it passes through the filter when it's really cold, so I would image that the wiring being disconnected won't be helping either starting or running when it's cold.
    Plug it back in - which needs to be done in any case - and see what difference it makes. If it doesn't resolve the problem, then you'll have to continue your search.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    As james says plug it back in.erase codes then run engine,recheck codes if you still have 400 remove egr clean and refit.it's not a bad job on the dti
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Random Plug Next to pollen filter???
    By Kev_G in forum Vectra C / Signum Troubleshooting
    Last Post: 26th July 2011, 10:08
  3. What Is This Plug/Connector For? (nr pollen filter)
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 18:43
  4. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
vectra c fuel filter plug
