Results 1 to 10 of 19
Thread: 1.9 CDTi Slight misfire
    Regular Member djr69uk's Avatar
    Midlands
    Default 1.9 CDTi Slight misfire
    What does occassional lumpy cold idle and occassional misfire/juddering at about 1800k sound like? I've just cleaned EGR and boost valve... they appear OK. No EML or spanner. Drive OK but just not 100%. Are these 3rd injector loom symptoms?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    That is usually the EGR or 3rd Injector plug.... you can clean the plug with some WD40 and see if it temp fixes it. Was the EGR fully cleaned out (both sides stripped and cleaned)..?
    Midlands
    yes the EGR was removed and soaked in WD40, then I split the solenoid from the valve, but I didn't need to drill out the solenoid as this was nice and springy still. prior WD40 sessions seem to have kept this free of corrosion. i'll whip the 3rd injector plug off later and have a look. thanks
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by djr69uk View Post
    The valve might be springy, but may not have its full travel though, I found this with one I previously took off mine.
    Certainly worth cleaning up the injector plug anyway though.
    Edinburgh
    Give the third injector connector a skoosh with WD40 if it improves then replace the connector. What colour are you connectors? think the old ones are yellow, new ones blue if memory serves
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    lumpy idle could be an injector out of tolerance, hesitation/slight misfire approx 1800-2400k at part throttle is probably EGR
    Midlands
    just been outside and took the plugs off all the injectors - they are the yellow clipped originals. plugs 1 and 2 looked fine, 3 and 4 had some brown crap on them. WD40'd as suggested and into the injector connectors. wiggled to ensure a good connection, but don't think it has helped... still not idling 100%. oh and checked state of wiriing to connector on injector loom 3. seems fine under there too...
    Midlands
    Quote Originally Posted by plasma View Post
    would opcom be able to diagnose something like an injector fault?
    Regular Member justyb's Avatar
    wigan
    sounds like 3rd injector changed mine last week had the same probs
    Midlands
    Quote Originally Posted by justyb View Post
    similar symptoms and did you just change the 3rd inj loom part or the actual injector itself too?
  1. 3.2 GSi slight misfire, need help....
    By TimTay in forum Engine & Drivetrain
    Last Post: 19th August 2011, 11:10
  2. Slight misfire at idle
    By Lozza in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2011, 06:52
  3. Slight Misfire & (Intermittent) No Power When Engine's Cold (1.9 CDTI 150)
    By DanR in forum Vectra C / Signum Troubleshooting
    Last Post: 11th March 2011, 21:13
  4. Slight CDTI misfire
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 2nd June 2010, 17:46
  5. cdti 150 slight misfire! help needed
    By craigz9876 in forum Engine & Drivetrain
    Last Post: 30th October 2009, 11:11
