Results 1 to 10 of 13
Thread: do 07 vectra c still suffer clutch judder
    luton
    Smile do 07 vectra c still suffer clutch judder
    Hi all good to be here I have a vectra 1.8 life and am very pleased to have it just a couple off probs its 07 and only done 30.000 and has split pesonality almost like clutch judder but not it seems the ecu is over compensatin holding revs up in gear change and causing alot of judder its difficult to drive it calmly when mother in law on board thats the first thing the other is just me and gadgets how can I get it to do all round lights when I unlock the car or lock it I do what it said in instructions hold door open pull main beam stork and they come on for 30seconds I want it to do that all the time but it forgets that I have acctivated it they call it door to door lights is it ment to forget lol
    Jul 2009
    The Rift, Cardiff
    I think the high revs between gears are to do with the dmf. Not too sure bout the juddering tho, I have the same problem on my 1.8.
    The feature with the lights only works the way you described, ie only when you leave the vehicle. If you want them to come on with key activation I think it can be programmed with tech2 or you could wire some drl's to the dash/switch illumination.
    Bill
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    Sorry to leap in but I dont think that the 1.8 petrol has a dmf. My 06 plate doesn't
    Regular Member Steevo's Avatar
    kent
    My 07 1.8vvt sri 36k judders aswell really annoying.
    Do they not have a dmf?
    Wot else could it be?
    Steevo
    Jan 2008
    west yorkshire
    I'm almost sure that none of the 1.8 petrols have a solid flywheel, not dmf. Other members say to check engine mounts as this can cause juddering. Try a search on here for clutch judder and see what comes up. Good luck
    Jan 2008
    west yorkshire
    oops sorry typing error. meant none of the 1.8 petrols have a dmf. they all have a solid flywheel
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    you right 1.8 does not have dmf vauxhall are having lots of problems with clutches on petrol cars they have even changed materials but still have problems the fix now has been flywheel and clutch kits
    luton
    Yeah not got dual mass flywheel which I have just see the animation for and can see why they rattle lol finding it hard to see the benefit mine is a solid fly wheel it tends to send me in to a wheel spin off every junction or slip the clutch to avoid judder and as for slow motorway traffic its hell people think im angree as I have to jump forwards cant have relaxed drive and its makin my other half feel sick lol
    Jul 2009
    The Rift, Cardiff
    Quote Originally Posted by yessof View Post
    True, I was tryin to remember what I had read somewhere on here a while back and got muddled up (easily done).
    Solid fly wheel sounds cheaper than a dmf too.
    So the high revs between gears dosen't happen with the dmf?
    Regular Member videodoctor's Avatar
    Blackpool
    My old 07 plate 1.8 vvti vectra suffered from clutch judder at only 2500 miles.They fitted a new updated clutch and flywheel but the judder returned after only 2000 miles.It wasn't quite as bad with the new one as the old but it would still judder mainly when warm.This.among other reasons, is why i traded it in because the 3 year warranty was due up and i didn't fancy paying out for it myself.
  1. Pre April 07 Vectra 1.8 SRi Recalls for Clutch Judder?
    By Mark_SRi in forum Engine & Drivetrain
    Last Post: 13th January 2011, 13:41
  2. Clutch judder
    By andy1103 in forum Engine & Drivetrain
    Last Post: 17th November 2010, 21:19
  3. Vectra Cdti 1.9 Clutch Judder
    By CHRISSMART41 in forum Engine & Drivetrain
    Last Post: 14th October 2007, 11:15
  4. clutch judder
    By brian75 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2007, 13:30
clutch shudder when hot on vauxhall Vectra
07 vectra 1.8vvt clutch
vectra c judde clutch when road is wet
vectra c cdti clutch judder
vectra 1.8 judder in traffic
do petrol vauxhall.vectras have a.dmf
clutch judder 2007 vauxhall vectra
vauxhall vectra clutch judder
how much is clutch for vectra c 1.8 vvt
vectra c clutch miles
vectra 1.8 Vvt clutch is it dual mass
