Results 1 to 10 of 17
Thread: 1.9 cdti swirl valves.
    Regular Member sla002's Avatar
    hayes, middlesex
    Default 1.9 cdti swirl valves.
    hi to all,
    i'm new to the sit and could do with some help.
    i've got a 2005 1.9 cdti 150bhp with the normal swirl valve problems , the valves are all free moving and the actuator that controls the valves seems to work fine. the only problem is at the momment the link bar keeps falling off as the cups on the bar that fit over the valves are badly worn, i've been to vx and i can't buy just the bar i have to buy the hole manifold at a cost of £225 which i dont really want to do. i.ve heard there is a £1 fix that can be done, can anyone tell me where to get the info on this fix and if it works or not.
    cheers.
    any help would be great.
    hayes, middlesex
    hi again.
    someone must have an idea, this is doing my head in, for such a common problem you would think by now there would be some kind of fix.
    please help!!!!!!!!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Welcome.
    There is a how2 for the cheap fix here... (you may need to be a full member to see it though)... see here for the membership details.
    This cheap fix more often doesn't work than does (but I suppose is well worth a go), and requires a new inlet manifold to fix at about £600 fitted at VX (as they don't seem to replace the actuator) or about £800 all in with this changed also.
    hayes, middlesex
    cheers mate, i'll have a look, nice one.
    hayes, middlesex
    managed to see it, seems like an easy fix, going down b&q now.
    be back on later with the results.
    cheers again.
    11 Post(s)
    Quote Originally Posted by sla002 View Post
    hi to all,
    i'm new to the site and could do with some help.
    It might help your cause if you were ask your question in the appropriate forum.
    "Swirl valve problems" would be best asked in the "troubleshooting - engine & drivechain" section, not the "introduce yourself" section.
    The clue is in the title
    EDIT - I see it's now been moved.
    Edinburgh
    £225 doesn't seem bad for fixing the inlet manifold, I thought it was mega-bucks usually? or is that just the part with no labour?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Big Knox View Post
    That'll be part only, and an expensive one at that, they tend be around £160 for the manifold only.
    hayes, middlesex
    hi,
    results where negative on swirl valves, this mod stopped the valves from opening at all.
    back to the drawing board.
    £225 was part only from vx.
    where did the quote for £160 come from.
    thanks big dave, as i said new to the site yesterday, but i will keep that in mind next time i ask for help.
    cheers
    Regular Member P3tchy's Avatar
    Milton Keynes
    This is where I got mine from, Arrived next day as well.
    http://cgi.ebay.co.uk/Vauxhall-Induc...item2c52fa4f50
  1. Swirl Valves......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 5th July 2012, 19:16
  2. Glueing Swirl Valves in place on CDTI 150?
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 06:43
  3. Swirl valves
    By MattHD in forum Engine & Drivetrain
    Last Post: 18th April 2011, 12:45
  4. swirl valves
    By srimike in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2010, 19:52
  5. Swirl Valves
    By dhwigston in forum Engine & Drivetrain
    Last Post: 2nd March 2010, 15:13
