Results 1 to 10 of 14
Thread: V6 3.0 CDTI Injectors
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    StatsVehicle Info
    Default V6 3.0 CDTI Injectors
    Seem to have an oil leak from the top of no.2 injector on the front bank.
    Anyone had any experience of removing the injector and replacing the seal?
    Regular Member Celes's Avatar
    Slovenia, Koper
    StatsVehicle Info
    You have to remove:
    Inlet manifold, common rail, pipes leading to common rail, rocker cover, various coolant pipes and sensors, etc.
    Good luck.
    StatsVehicle Info
    Since your car is probably out of warranty, find a local diesel specialist and ask if they have experience of the Y30DT engine
    I wouldn't recommend doing injector replacement unless you can guarantee the area you are working in is perfectly clean, otherwise the replacement injector may not work correctly
    Equally, if you are replacing one injector you may as well replace the other five, but that will push the price up considerably (from memory each injector is near on £100)
    Slovenia, Koper
    StatsVehicle Info
    Oh no m8internet...each injector is 700+ at dealers
    I have a full set of injectors from a broken motor that worked fine before the liners dropped.
    My mechanic who never saw a Y30DT did the job perfectly. I was watching all along and no special tools were needed, the rear bank can be tricky though but he made it seem like a doddle
    StatsVehicle Info
    Quote Originally Posted by Celes View Post
    Prices vary by country, as we have found!
    Here in the UK the injectors seem to be reasonably priced, I only got a quote a few weeks ago, £108 plus VAT, per injector
    Slovenia, Koper
    StatsVehicle Info
    WHAT? ONLY 108 QUID? There can't be a 600% difference
    StatsVehicle Info
    That's just the injector alone...
    Slovenia, Koper
    StatsVehicle Info
    I got quoted 760€ for 1 injector at Opel. 5€ for gaskets on 1 injector.
    StatsVehicle Info
    That works out at £650
    However that may be the entire injector assembly
    Slovenia, Koper
    StatsVehicle Info
    760€ or so...for 1 like this one
  1. CDTI 150 Injectors
    By sri150 in forum Engine & Drivetrain
    Last Post: 8th November 2011, 15:34
  2. Replacing CDTI injectors
    By phil147 in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:09
  3. Injectors x4 1.9 cdti 150
    By mark230678 in forum Parts for sale
    Last Post: 30th June 2009, 22:05
  4. 3.0 CDTi Injectors
    By Robbieben in forum Parts for sale
    Last Post: 1st February 2008, 23:17
vectra 3.0 cdti injectors
removing injector 3.0 vectra v6 cdti
vectra 3.0 cdti injectors removal
