ive got a 2.2 petrol sri pre facelift none direct, will the dual exhaust from a 2006 facelift 2.2 sri z22yh fit straight on?
if not what would need doing?
have sorted the twin exit insert.
it should fit mate. you'll need to get a y splitter made though
nice one
The centre boxes are different bobby, the SE one is huge, goes from the flexi all the way to the fuel tank. I'm sure the direct only has a small box. You might be able to fit it to the down pipe though as I think both manifolds are the same. If all else fails and the diameter of the two pipes is different, just cut both systems before the Y and clamp the larger pipe over the smaller, this is what I did with a 2.0T system on mine.
Oh Mr Bobby twin pipes............................
Pics when fitted![]()
will i need to weld an exhaust hanger on the right hand side for the other back box?
dont think so mate should be one there
