Results 1 to 10 of 17
Thread: Instant fuel consumption
    west sussex
    Default Instant fuel consumption
    Just wondering if anyone could give me some pointers in investigating why my instant consumption displays complete random numbers even when holding a constant speed using cruise control. All other features of the trip computer appear ok ( avg speed, avg consumption, range etc). I'm hoping its something simple like a sensor to clean or adjust.
    Any help would be much appreciated
    Dunstable
    I believe this is normal, mine does it too, even with cruise control, it's constantly changing the amount of fuel it's using to maintain the same speed wether it's up/down a hill etc.
    Oct 2009
    rhyl
    its not ment to be 1 figure its what your getting at that very moment which changes dependin on hill up or down
    west sussex
    Thanks but when I say random I mean 234, 750, 999, 43 etc anything constantly just going mad!
    Dunstable
    It can be random like that depending on the road conditions, if you want a more stable reading you need to switch to you average consumption view...
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Quote Originally Posted by yieshkebob View Post
    any car with a trip computer will do that, its totally normal. youll find that the higher numbers will appear when youre going downhill & the cruise control has closed the throttle, therefore using little or no fuel as you drive downhill. as you go up a hill the numbers will reduce as the cruise control opens the throttle, therefore using more fuel, increasing the fuel consumption.
    also,
    Regular Member IrishWhiskeyChaser's Avatar
    Jan 2010
    Ireland
    As intimated by the others above Cruise control is not a constand rev it's a constant speed. When going up hill the engine has to worker harder to keep the speed at the desired level.
    It shouldn't be that volatile, although it's not very accurate below 40mph
    Equally, it depends on the type of road and gear being used
    Once I am at the set speed it normally returns between 15 and 80mpg, only going above this on steep declines but usually the cruise control switches off due to overspeed
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    yours switches off due to overspeed? must be something wrong with your cruise id say. mine keeps a steady speed up & downhill & i have a manual 1.8.
    ive only ever experienced any cruise control switching off after it drops approx 10mph below the set speed & i drive an automatic 5.4l ford econoline van, which has cruise control, for work, never had the cruise switch off on that when going downhill & 'overspeeding'.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I think he means when it cuts the throttle off for a hill
  1. Fuel consumption
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 19:16
  2. Fuel system treatment & Instant Engine
    Last Post: 10th December 2011, 21:11
  3. instant consumption gone weird!
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2010, 20:00
  4. Fuel consumption
    By james chambers in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2009, 17:20
  5. fuel consumption on v6 dpf
    By lexicon in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 23:47
vectra c range and fuel consumption display wrong www.vectra-c.com
https:www.vectra-c.comforumshowthread.php102319-Instant-fuel-consumption
