Results 1 to 10 of 17
Thread: Front hub nut
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default Front hub nut
    Hi, Does anyone know the size of the nut that holds the front hub on to a 2003 Dti?
    Oct 2009
    Swindon
    32mm I think mate
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    as above but you'll need a 32mm 'deep' socket
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jan 2008
    Dundee
    cheers guys. Now i have a bigger problem. When tightening the steering rod back onto the knuckle, i over tightened and cracked the knuckle.
    Is it possible to remove the new bearing without damaging it, to refit an other kuckle?
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    Front hubs should come off without any problems/damage if thats what you mean?
    Are you talking about overtightening the track rod end which connects to the leg?
    Jan 2008
    Dundee
    Quote Originally Posted by plasma View Post
    yes. i just fitted a new wheel brg/hub and when tightening the track rod on to the leg it cracked.
    is it safe to be driving around with the knuckle cracked?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    No way buddy, I'd leave the car where it is just now until you get a new knuckle, that thing may get a shock from a pothole or something and crack right through
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    As above, if it breaks altogether then you'll have no steering control at all.. Leave the car where it is until repaired.
    Jan 2008
    Dundee
    aye thats what i was thinking lads
    Oct 2009
    CRAWLEY,WEST SUSSEX
    Sorry to be harsh, but if you need to ask that question,then perhaps you should'nt be repairing your car!!
  1. SRI Front bumper & Irmscher (copy) Front Spoiler
    By AJA in forum Parts for sale
    Last Post: 10th August 2005, 21:10
vauxhall vectra hub nut size www.vectra-c.com
vauxhall vectra 3.2 v6 driveshaft nut size
vectra hub nut size
vectra c front hub nut size
