Results 1 to 10 of 14
Thread: Pads are screeching! Please, suggest new
    New Member alexey88's Avatar
    Feb 2010
    Norwich
    Default Pads are screeching! Please, suggest new
    Hi guys! I got Vectra 2003 1.8, can you suggest me new both front and rear breaking pads for affordable price? The problem is that the pads are almost new but the noise is terrable. As I bought my Vectra recently I dont know which are the good one. Help!! thanks in advance!
    Regular Member kentish_bloke's Avatar
    Mar 2008
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    if the pads are new, did you fit them yourself? if so, remove them & put a smear of copperslip on the metal backing to the pads. then refit. should solve the problem, although i seem to remember my rear pads had anti squeal backings to them. copperslip cant do any harm though, so long as you dont get any on the friction material.
    as for replacements & cost, VX pads arent that expensive & after a bad experience with some ferodo pads i fitted to a previous car, standard manufacturer pads are 100% recommended, imho.
    Regular Member frasedeb's Avatar
    Mar 2009
    hull
    main dealer pads are best bet, not overpriced.
    Blantyre
    I had this issue on my old vectra, turned out to be the wrong pads fitted, got a set from the loacl motor factors and sorted the bus squealing type braking
    Oxfordshire
    13 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    It's best to change the discs at the same time as when changing the pads.
    Pads these days are equally as hard as the discs and often wear down at nearly the same rate.
    Also, it's cheaper to but a disc & pad kit from Vx than it is to buy the pads and discs separately from them. This is to help encourage people to change both the pads and discs at the same time.
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    Year : 2003
    I've bought these, and are fitting them at the weekend.
    Quick delivery and i've used them on several cars and they make a good improvement on standard.
    Says for the 2.2 but confirmed same as the 1.8.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Quote Originally Posted by Waterboy View Post
    The pads are good if not a little dusty, its what I use, cant comment on the disks as there not Mintex.
    To the OP, as said a good lick of Copper slip works wonders on the little blighters, it also gives better feel as well.
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I fitted Mintex discs and pads all round to my 2t almost two years ago with no regrets at all...
    Feb 2009
    Edinburgh
    Any idea of price of the kit?
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    Year : 2003
    Quoted from VX Dealer, Greenhous in Telford:
    Front discs and pad kit = £85.19 inc vat
    Rear disc and pad kit = £85.78 inc vat
    Obviously check your dealer as i'm advised they appear to make up their own prices!!
  1. Could someone suggest........
    By eve01rton in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 22:59
  2. screeching when starting ??
    By mccluskey119 in forum Engine & Drivetrain
    Last Post: 9th August 2011, 23:52
  3. Knocking and screeching
    By Fulgrim in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2008, 17:42
