Thread: removing standard air feed
    Regular Member GSi-Col's Avatar
    Aug 2009
    Kirkcaldy, Fife
    Default removing standard air feed
    Got my pipercross viper to fit over the next few days but need to figure out how to remove the pipework between the airbox and the front grill
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    from the airbox to the grill...
    remove the screws thats in the top, then you should be able to press, slide back the airtube... but will be very firm to get out and will probaly break.. (mine did)
    seach for how 2 change for VXR air feed..
    Aug 2009
    Kirkcaldy, Fife
    Quote Originally Posted by kenp View Post
    cheers i had a look but was a broken link
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by GSi-Col View Post
    Does the existing air intake run across the top of the radiator or is it the shorter type?
    If, like me, you've got the longer type, I found the easiest way was to hacksaw it into bits as it seemed impossible to remove without dropping the radiator.
    Engine : 2.2 Direct
    http://www.vectra-c.com/forum/showthread.php?t=27708
    it is possible to remove it without a hacksaw i did...
    Regular Member old cruiser's Avatar
    slough
    I removed mine and fitted the shorter intake on my Z22SE; a few months ago put the longer one back on (due to some running issues) and didn't remove rad' but have to say it's worse a job to put the longer one back on!!
    Cheers Pete
    Full Member Signum Dek's Avatar
    South Yorkshire
    Long one can be got out with a bit of pulling and tugging, but mine wasn't in a reusable state after.
    Half Leather Interior - Spax SS Springs - Bilstein B4's - K&N Filter/Airbox Mod - GSI Intake - Twin Chrome Tipped BackBox - Richbrook Door Pins - Irmy Alu Top Grill - Irmy Roof Spoiler - Irmy Pillar Trims - Stainless Sill Plates - Heated Washer Jets - 50w 6000k HIDs - Moulded Mud Guards - 18" VXR Replicas - Travel Assistant - CID & NCDC 2015 - Electric Folding Mirrors - Irmy Mirror Covers - Chrome Handles
  1. resetting trip computer after removing standard radio
    By forde in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2013, 11:25
  2. Removing standard headunit
    By Polish08 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd September 2012, 23:22
  3. Replies: 4
    Last Post: 28th May 2012, 22:58
  4. Standard Air Pipe Feed - anyone done this?
    By Leemarksmith in forum Petrol Engine related
    Last Post: 2nd August 2008, 14:51
