Thread: graunching noise from front
    Full Member gibbon7000's Avatar
    lincs
    Default graunching noise from front
    At xmas I changed my front springs, Ive done about 4k miles since then and now when i turn left or right i get a horrible graunching noise coming from the wheel area. Everything is fine in a straight line. I'm gonna get it jacked up as soon as i can but in the mean time does anyone have any suggestions as to what it could be???
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    WGAF#5
    ello mate
    is the graunching noise when stationary/low speeds??
    if so did you fit spring sheaths when you replaced them??
    if not then it sounds like the spring moving on its mount ?
    sheaths available from vx fit to the top and bottom of the spring there a few quid
    Full Member Big Sig's Avatar
    spring sleeve mod, have a search, could be that.
    lincs
    ello mate
    No not when stationary, only when wheels are moving. I re fitted the old spring sheaths to the new springs.
    WGAF#5
    disc protectors rubbing on the discs ?
    Oct 2009
    Swindon
    could be steering bearings under the top mount?
    drop links?
    Oct 2009
    Swindon
    it's a vecta, change all the above! you'll have to sooner or later! lol
    Regular Member watchman's Avatar
    Apr 2009
    Leeds
    Engine : Z28NET
    Mileage : 75000
    Graunching.
    What a great word.
    When I read it I thought it must be one you'd made up.
    But Google says not. Brilliant.
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Quote Originally Posted by damian s View Post
  1. Noise from front end?
    By Hodgy in forum Suspension, Wheels & Brakes
    Last Post: 26th April 2016, 14:27
  2. Replies: 3
    Last Post: 8th September 2012, 12:13
  3. Front end noise
    By Handyandy-UK in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2010, 22:35
  4. Nasty graunching noise from front :(
    Last Post: 21st February 2010, 23:45
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
