Results 1 to 10 of 24
Thread: towbar advice
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default towbar advice
    hi guys i have a vec estate 2006 cdti sri i have just got a towbar from towequip and it came today it has 6 bolts that go through the boot floor i need to drill 20mm holes for the bolts and i have a plug in can bus electrics for 12 n and s is it just a case of plugging in them and thats it off i go???
    also any tips or advice would be great before i try and fit it.
    also when i drill the holes how will i def know they are in line with the chassis holes??
    like i say any advice or tips would be great cheers guys
    Full Member
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    There should be pre-indented markings in the boot floor where you drill the holes. Use a hairdryer or heat gun to soften the soundproofing/rubber coating inside the boot floor and then scrape it away. Check carefully which plate goes on which side and then use one of those stepped cone drill bits to ease out the holes to the right size - I thought it was 22mm from memory but you'll soon see.
    Get some good underseal - the stuff that dries firm - and paint the towbar prior to fitting as you won't be able to reach it all once fitted. I fitted a hatchback bar without removing the bumper. The electrics were just plug-and-play for me, some have said they needed to use the tech-2 to enable them.
    Oct 2009
    rhyl
    hi mate my dad has recently fitted a towbar,you need to check that you have plug in your rear fuse box for the plug as some don't and also my dads needed tech 2 so he got it wired by a towbar place as if you just join the wires to the rear lights it wot work they have to fit a relay but works out cheaper than tech 2
    Regular Member scottyd's Avatar
    paisley
    hard wire into rear light electrics mate no need for tech2
    kings lynn, norfolk
    hi all thanks i have bought the dedicated kit with the lom and trailer block which is stamped gm i have plugged that in and also plugged the lom in just to test and it looks all dead no electric gettin there at all does this mean i need it tech 2 or will my op com be able to enable this if so what do i need to go into in op com?????
    as for drilling will one of those round cud drlls be ok the instructions say 20mm for the bushed to sit in the the towbar fits on with bolts.
    the towbar has come painted in black so thats all ok
    i am fitting it on sunday night or mon night with a mate so should be ok
    i take it i will line it up and see which 3 dimples match the holes on the plates then???
    Full Member
    Jan 2008
    Lincs
    Year : 57
    Mileage : 100k+
    I used one of these:
    eg: http://www.screwfix.com/prods/15976/...p-Drill-4-22mm
    Got mine from the market - unless you plan to go into business it doesn't need to last longer than the holes you need now.
    I got the Vx wiring kit and it just worked. The holes you drill in the floor allow the shank of the bolts to pass through. The threaded bits pass through smaller holes which are already drilled in the bottom surface of the chassis rails. The towbar bolts up tight to the bottom of the chassis rail to the shoulder of the bolts.
    Leicester
    DO NOT hard wire into the electrics.
    I know many people this and it sometimes works. But it is for sure NOT good practice.
    Winnie, if you have gone to the effort of buying the proper electrics, then don't short cut it. You will have the place to plug in the control module and also the loom plug.
    You will need to tech 2 the car to tell it the tow electrics are present. I have known of people do it with op Com but not done it myself.
    I have done about 8 Vectra C towbars now and never come across one without.
    kings lynn, norfolk
    ok cheers guys i will let you know how i get on and will ask if i need any more advice cheers i will take some pics too if its not too dark
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    You dont have to Tech 2 for the tow bar electrics to work, as long as you have the module and fuse in place you will have power to electrics, Tech 2 enabling the towbar electrics only allows canbus to detect for bulb failures and the towed vehicle directional indicator warning on the instrument panel
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You cannot simply connect Vectra Towbar electrics into the rear lights, as tail / brake works the same bulb filament on different voltages.
    You CAN hard wire in, but it's a bit more complicated. I did it his way, using relays for tail and stop lights. Indicators ran straight off the rar light fittings.
  1. Towbar advice
    By jasonblake in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2011, 15:40
  2. Towbar electrics- help/advice please
    By Craig1985 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2011, 06:08
  3. Buying a towbar, Advice please
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2010, 10:12
  4. Towbar advice
    By heckmotor in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2010, 12:26
  5. Towbar advice
    By Jax in forum General Chat
    Last Post: 23rd February 2008, 18:23
